pic: Team 604 Electronics Board 2009
Re: pic: Team 604 Electronics Board 2009
Very nice and clean. I like it.
It does look nice but if you have a problem with the four jags on the bottem they are going to be a pain to get at and fix/replace
also, did you guys remember to keep the 1/2" clearance between the top of those bottom jags and the bottoms of the jags on top? if not have you guys had any problems with the temp of your jaguars?
It's kind of hard to tell in this picture, but there is clearance |
I do like how clean everything is. Are you sure that the battery will stay put or are you going to put velcro between the battery bottom and the board? Just a suggestion.
Where is your on/off switch?
It appears to be behind the Battery.
The battery was secured with a wide Velcro strap that wrapped around the bottom of the board and up around the battery.
| pic: Team 578 electronics board | commodoredl | Extra Discussion | 3 | 02-02-2009 21:02 |
| pic: Team 604 -- 2009 Teaser #2 | natalie604 | Extra Discussion | 1 | 29-01-2009 17:23 |
| pic: Team 604 -- 2009 Teaser #1 | Eugene Fang | Extra Discussion | 8 | 19-01-2009 23:22 |
| pic: Team 1676's Electronics Board | Graham Donaldson | Extra Discussion | 9 | 20-02-2007 10:18 |
| pic: Team 1701 Electronics Board | imax48236 | Extra Discussion | 10 | 29-01-2007 20:18 |
