Go to Post What happens when everything becomes fully swagged out? Also, does my robot need to have collar-popping functionality to use every feature? - AlecMataloni [more]
Unread 14-02-2009, 09:22
shoffing's Avatar
shoffing shoffing is offline
WINriver C++
AKA: Steve Hoffing
FRC #1647
shoffing is an unknown quantity at this point
Question Problem Configuring cRIO
We have problems:
  • Problem configuring the cRIO
  • Reformatting the cRio via safe mode takes at least an hour and never completes!
  • We can't set the IP of the cRio, it stays set at 0.
  • What exactly is the "on" and "off" position of the DIP switch? Can someone give us a diagram?
  • What should the default subnet and gateway Max tools configs should be?
  • The status LED blinks every 2 seconds.
Problem receiving console output from cRIO Arborama Programming 7 15-02-2009 03:30
cRio corruption/polling problem nathanww Technical Discussion 1 04-02-2009 23:24
cRIO Problem Pneumaticsman NI LabVIEW 8 10-01-2009 11:59
cRIO plugin problem gabrielse National Instruments LabVIEW and Data Acquisition 3 18-12-2008 11:30
cRIO test drive *OFB* problem.... NetSkay FRC Control System 5 10-12-2008 18:32
