Go to Post Remember that starting a team is ALOT of work, but it’s a lot of fun once it gets going. Its all about the students, so don’t get too carried away ;) - Travis Covington [more]
Unread 14-02-2009, 09:31
Ori2630 Ori2630 is offline
FRC #2630
Ori2630 is an unknown quantity at this point
Autonomous Issue
Hi,
so.. I have some problems with the autonomous...it just won't work, I'm using the advenced frimwork on LabVIEW, and I'm also using Iterative autonomous mode (or something).
I'm trying to make the motors get a diffrent value every 3 secends...but when I put a sleep function of 3 secends and a while loop, the motors move for a moment and then they stop for 3 secends...
what can I do??
Ori-2630
Unread 14-02-2009, 09:32
airnate airnate is offline
FRC #0236 (Techno Ticks)
airnate is a jewel in the roughairnate is a jewel in the roughairnate is a jewel in the rough
Re: Autonomous Issue
Can you post you code so we can suggest revisions?
Unread 14-02-2009, 19:38
If the watchdog is opened, then it needs to be fed during the three seconds. To do this there is a VI in the palettes called Delay and Feed. Use it instead of the plain delay. The other option is to set the timeout on the watchdog bigger than your delay, or to disable it.
Greg McKaskle
Debugging issue dpeterson3 C/C++ 3 11-02-2009 20:11
Lag Issue bizarospooky Programming 7 08-02-2008 17:31
decoder issue TEAM1949 Programming 10 07-03-2006 14:34
printf issue Max Brin Programming 6 24-01-2006 17:03
Autonomous issue NJ M. Hicken Programming 2 16-02-2005 21:59
