Holding of program
Our code is not keeping loaded on the machine. We have had it work and then we come in again and it needs to be downloaded again. The blue box on the driver station says "No COMMS" or "NO CODE". The 2 jaguars are blinking green and we have lights on the Lynksis. Any ideas? I hope I have described it well enough.
Also one team member wanted to know if we are suppose to have a backup battery pack like previous years. If not, what replaced it? Robot runs fine if we use the wires connected to the battery, without using the driver station at all. If that helps anyone with helping us. Last edited by chinckley : 14-02-2009 at 12:26. Reason: more detail |
Re: Holding of program
Perhaps they mean that the system runs when they hook up the motors directly to power? Some clarification is needed.
And yeah, NOTHING should be running on the robot with a "No comms" o "No code" error--you should check that your DS is updated correctly. |
What does Nathanww mean by DS? We installed Update 3.0a. Thanks so much for answering. We are getting nervous that there is something really wrong with something. No idea what though. Carolyn Last edited by chinckley : 15-02-2009 at 13:29. Reason: color change of blinking lights. |
We got it today. Thanks for pointing us to the FRC Framework we found on page 13 of 17 the directions for downloading to the cRIO and having it stay on startup. They must have been downloading it using the Run button or from startup, not the way that saves the code. We powered down and up a few times and it worked and kept the code.
Thanks to everyone. Carolyn |
| pic: 612 holding two! | RoboMadi | Extra Discussion | 15 | 05-03-2007 10:56 |
| Holding a position in our arm | brennerator | Programming | 2 | 17-02-2007 04:02 |
| Pneumatics holding their position | sanddrag | Pneumatics | 22 | 15-01-2004 16:36 |
| Robot holding a ball... WIP ..image | Salik Syed | 3D Animation and Competition | 7 | 03-01-2004 22:27 |
