Go to Post Competitions are won or lost far away from witnesses, ... In those long hours, is where we find inspiration in ourselves. For what inspires is not another's feats, but realize we have the power in ourselves to achieve that feat. - Mark Sheridan [more]
Unread 14-02-2009, 12:18
xela700's Avatar
xela700 xela700 is offline
Awesome-X
FRC #1591 (Greece Gladiators)
xela700 is an unknown quantity at this point
Controlling 2 pneumatic valves w/ 1 spike
Is using two pneumatic valves on one spike legal? How should I connect them?
Unread 14-02-2009, 12:24
Urban Hawk Urban Hawk is offline
Head of R&D and Head of Scouting
FRC #1886
Team Role: Scout
Rookie Year: 2007
Urban Hawk is infamous around these partsUrban Hawk is infamous around these partsUrban Hawk is infamous around these parts
Re: Controlling 2 pneumatic valves w/ 1 spike
yes it is legal.
<R48> Each power-regulating device (speed controller or relay module) shall control one and only one electrical load (motor, actuator or compressor).
A. Exception: Multiple low-load, pneumatic solenoid valves may be connected to a single relay module. This would allow one relay module to drive multiple pneumatic actions. No other electrical load can be connected to a relay module used in this manner.
as for connecting them just attach the 2 positive wires to the same spot on the spike and do the same with the negatives.
FEAR THE HAWK!!!
Unread 17-02-2009, 13:27
Ziaholic's Avatar
Ziaholic Ziaholic is offline
Elec/SW Mentor
AKA: Marc
FRC #1164 (Project NEO)
Ziaholic is a jewel in the roughZiaholic is a jewel in the roughZiaholic is a jewel in the roughZiaholic is a jewel in the rough
... actually, you'd need to put +12v and GND on the input side of the spike from your power distribution board, then, on the output side of the spike, you wire up the RED wire from the first solenoid to M+, the RED wire from the other solenoid to M-, and take both of the blacks from both solenoids back to ground.
Drive the spike "forward" and you get one solenoid active, drive it "backward" and you get the other solenoid active.
There are 10 types of people. Those who understand binary, and those that do not.
Team #1164 - Project NEO Robotics
Unread 17-02-2009, 13:32
EricVicenti EricVicenti is offline
FRC #0008 (Paly Robotics)
EricVicenti has a spectacular aura aboutEricVicenti has a spectacular aura aboutEricVicenti has a spectacular aura about
Also, you don't technically need to use a spike to control a pneumatic valve. You could just rig up the relay bumper on the cRIO. I'm pretty sure its legal to hook up two solenoids to one connection on the relay bumper, but I'm not positive, so as our team says, RTFM. (Read the FIRST manual)
(And yes, the F in RTFM didn't always stand for FIRST)
Unread 18-02-2009, 07:37
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
Xela,
What you are asking is legal but not always desirable. I would suggest you check out the Spike manual on the IFI website http://www.ifirobotics.com/spike.shtml. There is some application notes in the manual that you might find useful.
Al
WB9UVJ
www.wildstang.org
________________________
Needing pneumatic valves Brown General Forum 3 20-02-2008 19:32
2 FESTO valves on 1 spike bhsrobotics1671 Electrical 12 08-02-2008 13:37
wiring pneumatic soleniod valves GeorgeC Pneumatics 3 07-04-2007 08:02
small pneumatic valves technic master Technical Discussion 8 07-10-2004 19:18
Pneumatic valves in 2004 Kit gburlison Pneumatics 2 13-01-2004 12:49
