Go to Post Must...squish....bugs... :p - nighterfighter [more]
Unread 14-02-2009, 15:14
Jill Jill is offline
FRC #2197 (Las Pumas)
Rookie Year: 2007
Jill is an unknown quantity at this point
RSL blinking/not working
Our team hooked up the RSL to the digital sidecar, just like the power diagram. Sometimes it works for a second, then starts blinking. Sometimes it blinks as soon as it gets power. On the digital sidecar, there's a little green light right by where the RSL is connected, and that's blinking. We've checked the connections and can't find anything wrong there. Everything else attached to the digital sidecar works fine. My teammates and I were under the assumption that the light is supposed to be solid. Is that correct? Has anyone else had this problem?
Unread 14-02-2009, 15:49
EricH's Avatar
EricH EricH is offline
New year, new team
FRC #1197 (Torbots)
Re: RSL blinking/not working
The small LED's meanings can be checked at http://decibel.ni.com/content/docs/DOC-3120
It sounds like either you have bad communication or the robot is disabled.
Past teams:
2003-2007: FRC0330 BeachBots
2008: FRC1135 Shmoebotics
Unread 14-02-2009, 19:40
lynca's Avatar
lynca lynca is offline
Andrew Lynch
FRC #2587 (DiscoBots)
lynca has a reputation beyond reputelynca has a reputation beyond reputelynca has a reputation beyond reputelynca has a reputation beyond reputelynca has a reputation beyond reputelynca has a reputation beyond reputelynca has a reputation beyond reputelynca has a reputation beyond reputelynca has a reputation beyond reputelynca has a reputation beyond reputelynca has a reputation beyond repute
Send a message via AIM to lynca
The light should be solid when your robot is enabled. It will blink when its disabled. Does your robot randomly become disabled or is the light just randomly blinking even when your robot is enabled ?
History: 624 - Cryptonite --> 118 - Robonauts --> 2158 - AusTIN CANS --> 2587 DiscoBots
Bio: Andrew Lynch "How I Work" ---- LinkedIn , Facebook, Twitter
Unread 15-02-2009, 00:03
PhilBot's Avatar
PhilBot PhilBot is offline
Get a life? This IS my life!
AKA: Phil Malone
FRC #1629 (GaCo: The Garrett Coalition)
PhilBot has a reputation beyond reputePhilBot has a reputation beyond reputePhilBot has a reputation beyond reputePhilBot has a reputation beyond reputePhilBot has a reputation beyond reputePhilBot has a reputation beyond reputePhilBot has a reputation beyond reputePhilBot has a reputation beyond reputePhilBot has a reputation beyond reputePhilBot has a reputation beyond reputePhilBot has a reputation beyond repute
funny, our BFL does the same. When the led flashes, so does the light. But when the led is solid on, the lamp still flashes. It's as if the lamp has a flasher bulb like a Xmas tree light.
We only have two of the lamp connections wired. I keep telling the kids to check the wiring diagram.
Phil Malone
Garrett Engineering And Robotics Society (GEARS) founder.
http://www.GEARSinc.org
FRC1629 Mentor, FTC2818 Coach, FTC4240 Mentor, FLL NeXTGEN Mentor
Unread 15-02-2009, 00:53
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
The lamp basically does have a flasher in it. The extra wire specified between the outer two connections disables it.
Unread 16-02-2009, 08:09
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
The large, external RSL needs to have a jumper installed. The jumper is installed between the La adn Lb pins at the light connector per the Robot Power Distribution Diagram.
Al
WB9UVJ
www.wildstang.org
________________________
jaguar not working Bwood16 Motors 12 13-02-2009 13:22
Camera not working... AG-chadd Programming 4 04-02-2009 22:10
Remembering not working EricH CD Forum Support 9 21-07-2008 07:43
p2 not working? Lone_Wolf92c Programming 5 22-02-2008 08:49
IR Board Not Working (But NOT Fried) itsme Electrical 2 18-02-2008 06:11
