Go to Post When was the last time you heard of someone on their death bed talking about a great movie they saw? I think it far more likely to hear of their accomplishments, something they did to make things better. Well that's what FIRST is all about. - DougHogg [more]
Unread 14-02-2009, 19:29
GunfighterJ's Avatar
GunfighterJ GunfighterJ is offline
AKA: Joseph
FRC #2450 (RaiderBots)
GunfighterJ is an unknown quantity at this point
Question Autonomous Issues
We are using labview and the basic robot main.vi for our main code in the template that came with the software. Our issue is autonomous. We have tried putting it in several places and deployed the code permanently and the autonomous failed. Also after going into autonomous, the program or robot or something won't let us drive once in tele-op mode. Where is the correct place/way to create autonomous for a permanent deploy to the cRIO?
Unread 14-02-2009, 20:52
Re: Autonomous Issues
One thing that I've heard of other teams doing was right clicking to deploy just the autonomous independent VI. Instead, open the build specification under deployments, build, deploy, and set it to run as startup, the autonomous and teleop will automatically be hooked up.
Greg McKaskle
Unread 14-02-2009, 21:13
AKA: Joseph
Im not understanding what you are saying. What do you mean by deployments?
And I know how to run a code as start-up. What I don't know is which files to run as start-up(tele-op and autunomous, or just tele-op or just autonomous), or where to write the autonomous code.
There are 10 types of people in this world. Those that understand binary, and those that don't.
Unread 14-02-2009, 22:36
Sorry I wasn't clearer. None of the above. The Build Specifications folder under the cRIO will already contain a Deployment. That is the file that defines which files to download and to run. Clicking on the other files is still running source files.
Greg McKaskle
Unread 15-02-2009, 09:24
AKA: Joseph
Ok thank you for the help. So then would I write the actual autonomous code under autonomous independant then?
Unread 15-02-2009, 09:59
That is what the default framework supports.
Greg McKaskle
Unread 15-02-2009, 11:39
AKA: Joseph
Ok thank you.
IP issues brainsdmaner FRC Control System 1 07-02-2009 22:35
Autonomous Issues! dmoody92 Programming 6 07-02-2009 17:58
Autonomous questions (Labview) and some general issues Daniel_H NI LabVIEW 15 08-01-2009 21:07
VICTOR ISSUES merybar Electrical 12 15-02-2008 18:47
Sensor Issues Brian Connors Electrical 5 13-01-2008 09:48
