Go to Post Thank you to all of the mentors, You ARE changing the future. - chellyzee93 [more]
Unread 15-02-2009, 15:04
team877's Avatar
team877 team877 is offline
FRC #0877 (Cub Robotics)
team877 is an unknown quantity at this point
Setting speed values for a set more block (was: Hi)
Hi, ok this seems pretty dumb, and i'm sure there are other posts like this one out there, but how can i set a value for half speed on a set more block in Labview. I know the -1 is full out forward and 1 is full out backwards and i can do this, but when i try to put -1 for full speed and -.5 for half speed it won't let me do this. Any suggestions???
Unread 15-02-2009, 15:22
Re: Hi
Do you mean you can't enter in the number 0.5? It may be because the control is an integer. You may want to change it to a single or double float. It is set in the Representation item on the menu.
Greg McKaskle
Unread 15-02-2009, 18:32
airnate airnate is offline
FRC #0236 (Techno Ticks)
airnate is a jewel in the roughairnate is a jewel in the roughairnate is a jewel in the rough
Re: Setting speed values for a set more block (was: Hi)
One other thing to note is that if you are using arrow buttons (increment / decrement buttons) on a numeric indicator, they sometimes are set to increment and decrement by 1. You can change this behavior by
1. right clicking the indicaotr (or control) on the front panel and selecting Data Entry... (VI must not be running).
2. Turn off the Use Default Limits
3. Change the increment to 0.5 (or whatever you like)
Coerce will round values to the nearest increment value. This holds for keyboard entered values as well as increment/decrement buttons.
Setting the speed on a jaguar in C++ DillonMartine Programming 3 01-02-2009 11:26
Brake/Coast setting for speed controller cabbagekid2 Control System 0 16-02-2005 16:54
Brake/Coast setting for speed controller cabbagekid2 Electrical 0 16-02-2005 16:54
Speed Controller brake/coast setting steven114 Electrical 21 03-03-2004 13:05
What was the best team set up? xavior06 General Forum 6 15-04-2003 23:16
