Go to Post To limit FIRST to robots, tools, and competition is to strip away its immense potential. - Madison [more]
Unread 15-02-2009, 16:28
Anne_droid's Avatar
Anne_droid Anne_droid is offline
AKA: Anne Mitzel
FRC #0451 (The Cat Attack)
Anne_droid is an unknown quantity at this point
cRIO low execution rate
My programmers have asked me to post the following question, since they don't have their own CD account:
Right now as we run the cRIO we have 3 diffrent tasks one for Autonomous one for Teleop and one for the camera information, the camera information is put on to global variable so that the other 2 tasks can read the information. We noticed while running the cRIO that the input between the joysticks and the movement was laging some, so we found out the Hz that the cRIO was running at was around 13 per sec. We fixed up and cleaned up the code so that we only had the three tasks mentioned above and we increased the Hz to around 130. However when we run our turret and move and attemt to track the target we fall back down to around 30. when we delete the camera task from running the cRIO speed is still at around 300-500Hz. We are at a loss on what to do, testing on blank code it runs at 150KHz. And then with that blank code we put our camera task and camera stuff in, then it still ran at 55KHz. We cannot figure out what is causing these masive slowing in our code.
TrackTwoColors execution time Tom Bottiglieri C/C++ 18 17-02-2009 14:43
Single button function execution RonStoppable102 Programming 2 05-01-2007 09:45
User Processor Execution Time Andrew Blair Programming 1 12-02-2006 21:52
Actual execution time measurement Dan Technical Discussion 5 24-03-2003 11:36
