Go to Post umm i don't have a life. so no, i really doubt i'll go to the movies anytime soon. wait, does...april count as soon? - nehalita [more]
Unread 15-02-2009, 17:00
FTC 2891 FTC 2891 is offline
FTC #2891
FTC 2891 is an unknown quantity at this point
[FTC]: Problems with Motor Encoders?
Hey Guys,
Our team is encountering some big problems when it comes to the motor encoders on the 12V DC drive motors. It seems that the brass/copper thing the encoder collar is mounted to spins freely when it should be stationary. We have tried multiple encoders on multiple motors and they all have the same problem. The spinning encoder allows for inaccurate readings and allows the encoder wires to get chewed up in the gears.
Has any other team encountered this same problem?
What can we try to do to fix the problem?
Unread 15-02-2009, 18:13
ttldomination's Avatar
ttldomination ttldomination is offline
Sunny
Rookie Year: 2007
ttldomination has a reputation beyond reputettldomination has a reputation beyond reputettldomination has a reputation beyond reputettldomination has a reputation beyond reputettldomination has a reputation beyond reputettldomination has a reputation beyond reputettldomination has a reputation beyond reputettldomination has a reputation beyond reputettldomination has a reputation beyond reputettldomination has a reputation beyond reputettldomination has a reputation beyond repute
Re: [FTC]: Problems with Motor Encoders?
I do believe that the brass ring actually supposed to rotate freely but the encoder itself is not supposed to. The following link is the document on proper encoder assembly. http://www.education.rec.ri.cmu.edu/...cs/encoder.pdf
1648: 2013-2014
5283: 2015
Unread 16-02-2009, 19:03
cbhl cbhl is offline
AKA: Michael C
FTC #0481 (Thornlea Robotics)
Rookie Year: 2007
cbhl is on a distinguished road
The bottom of the encoder is supposed to be covered with a sticky adhesive (kind of like a label) and is covered with a piece of plastic-coated paper, if I recall correctly. Make sure you remember to remove the paper and stick the encoder onto the motor properly (as per the instructions).
Also, be careful with those encoder cables -- they're delicate. We managed to pull one of the ends off of one of ours -- so we can't use it any more. (We don't have the budget to buy another one and have it shipped all the way up here, anymore, either...)
Just my two cents.
Michael
Thornlea Robotics (FTC Team #481/#3431)
Programming Team Lead
http://thornlearobotics.ca/
[FTC]: [FTC]: Motor Problems fqzeng FIRST Tech Challenge 3 16-02-2009 19:12
[FTC]: Tips page on using FTC Encoders with LabVIEW PhilBot FIRST Tech Challenge 7 27-01-2009 14:00
[FTC]: Random Error with FTC motor control Xaphiinia FIRST Tech Challenge 2 01-12-2008 15:39
[FTC]: FTC Servo-Motor Problem with Labview dnhansen FIRST Tech Challenge 1 26-10-2008 00:43
[FTC]: [FTC] Motor Controller problems michael714 FIRST Tech Challenge 4 14-10-2008 00:33
