Go to Post Based on my experience coaching basketball and robotics, there is no doubt in my mind that if a sports coach receives $x then a robotics coach should, too. - dtengineering [more]
Unread 15-02-2009, 18:16
SuperBK's Avatar
SuperBK SuperBK is offline
AKA: BrianK
FRC #1225 (Amperage Robotics)
SuperBK is just really niceSuperBK is just really niceSuperBK is just really niceSuperBK is just really nice
Robot runs motors at last values when reconnecting
Our robot has "taken off" unexpectedly a few times. I think it may have to do with the lost of communications between the driver's station and the CRIO. So though I would FORCE some communication losses and see what happens.
For the moment, ignore why a loss might occur. We will move the wireless bridge on the robot to a better place for the competition.
It seems the controller on the robot remembers the last values of its motor drives when it looses communcations. If you turn on a motor and unplug the network cable from the drivers station to the router, the robot stops and goes into no communications mode (fast blinking robo signal light). When it establishes communication again, it runs the motor a short time and then cuts it off (if it the joystick is centered).
If you start a motor and then turn off the driver station and or router while the motor is running, it immediately turns off the motor which is good. When the driver's station and router are turned back on, it takes around 30 seconds to reestablish communications. When it does, whatever motors were running when communications were lost come back on. The motor(s) then run for 10-15 seconds before an update from the driver's station arrives and turns the motor off. The controls don't work at that point, only the disabled switch will stop it.
Finally a question: Is there a way to detect the no communications mode and turn off the motors. We are currently using the Simple template but have played with the Iterative robot base class. The robot is not disabled so I'm not sure the DisabledInit() method would be called.
My theory is that a short loss of communication will cause the robot to run out of control for 10-15 seconds.
Thanks,
Brian
Brian K
Team 1225 Robotics Mentor
Unread 15-02-2009, 21:39
p00rleno p00rleno is offline
Team Advisor & Former Team Leader
AKA: Andy
FRC #2590 (Nemesis)
Rookie Year: 2007
p00rleno is on a distinguished road
Re: Robot runs motors at last values when reconnting
LabVIEW code hasn't returned the same results you described here, at all if ours loses connection it just zeroes everything. Maybe, set all PWM Outs to zero in the C++ equivalent of TeleOp-Reset mode?
Just something to try
Snap Action Breaker Values for the Motors? ChuckDickerson Electrical 4 11-01-2009 14:00
Robot Runs in full Reverse EHaskins Programming 6 04-02-2006 23:39
FAHA: What happens when your team runs out of motivation? Ken Leung General Forum 14 24-03-2004 08:08
Last year's motors? archiver 2001 2 24-06-2002 00:33
