Error -1074396080 camera trouble
I have a setup for green particle finding and pink particle finding. Both have the same imput, coming directly from GetImage. However, during the ColorThreshhold, the pink particle identifier returns error -1074396080 with no explaination. I have tried changing out values and rewriting the VI but nothing has worked. Still, the green VI is working with no problems and the only differences are the HSL values.
What can be wrong? -- I've noticed that the second one to execute always has an error while the first one does not. Last edited by Kahn! : 16-02-2009 at 10:53. |
Re: Error -1074396080 camera trouble
Error number -1074396080 means "IMAQ Vision: (Hex 0xBFF60450) Invalid image type." (You should be able to right click and select "Explain error" where it occurs, or in LabVIEW select Help->Explain Error... to get error explanations)
If you look at the "Detailed Help" for ColorThreshold, you'll see this text: Quote:
You will need to use a second IMAQ Create, with type "Grayscale (U8)" to supply to the "Image Dst" input of the first ColorThreshold, otherwise it will overwrite your source image (U32) with the threshholded image (U8). |
| Trouble With Autonomous Camera Tracking | whswrestler189 | NI LabVIEW | 5 | 21-01-2009 19:20 |
| Error in code light on, trouble finding error | Bryan Herbst | Programming | 16 | 12-10-2007 21:59 |
| I'm having trouble with this camera stuff | Ianuser | Programming | 5 | 13-02-2007 10:45 |
| Camera servo trouble | Demothesis | Electrical | 5 | 27-01-2007 17:15 |
| Having trouble with your camera mount? | Chriszuma | Programming | 7 | 01-02-2005 22:12 |
