Go to Post The thrills of a heroic repair, a well deserved award, a compliment on our efforts, the growth of our team members, making new friends.... These can make a memorable and exciting FIRST regional as much as a close match. - Mark Pierce [more]
Unread 16-02-2009, 12:28
star_lancer's Avatar
star_lancer star_lancer is offline
Programming Addict
AKA: Mike Berney
FRC #2346 (CRASH)
star_lancer is a jewel in the roughstar_lancer is a jewel in the roughstar_lancer is a jewel in the rough
Send a message via AIM to star_lancer Send a message via Yahoo to star_lancer
Question Major compressor question
Do i need the solenoid from the compressor with solenoid example vi, I am running a lot of solenoids in the main program, and Just need to know whether or not I need that solenoid from the example in the program. Also, exactly where in the main vi do I put the compressor program?
If you found anything I said helpful, please click the scales next to my post. I really appreciate those reputation points.
Team 2346 - Build, test, panic, repeat.
Unread 16-02-2009, 15:44
Chaos in a Can Chaos in a Can is offline
Joel Spadin
FRC #1736 (Robot Casserole)
Rookie Year: 2007
Chaos in a Can is an unknown quantity at this point
Send a message via MSN to Chaos in a Can
Re: Major compressor question
I'm not too sure about the solenoid example vi, but if you are using the advanced framework, the easiest way to set up the compressor is to put a Compressor Open.vi and then a Compressor Start.vi in Begin.vi.
If you add a CompressorDevRef to RobotData.ctl, you can then wire the CompressorDevRef of the compressor Open to the compressor Start and then into your RobotData in Begin.vi.
Then, place a Compressor Close.vi in your Finish.vi and wire the CompressorDevRef from RobotData into it.
If you are using the basic framework, place a Compressor Open.vi and a Compressor Start.vi to the left of the top while loop in Basic Robot Main.vi.
Place a Compressor Close.vi to the right of the loop (near Drive Close and Joystick Close).
Finally, wire the CompressorDevRef from Compressor Open to Compressor Start and wire the CompressorDevRef from Compressor Start through the while loop and out the other side to the Compressor Close.
You shouldn't have to to anything more than open the compressor and start it. It will handle itself if you open it with the correct pressure switch and relay channels.
Hope that helps!
2006 Xerox Creativity Award
2007 General Motors Industrial Design Award
2008 Judges' Award
2009 Chrysler Team Spirit Award
Unread 16-02-2009, 16:43
Programming Addict
AKA: Mike Berney
FRC #2346 (CRASH)
that's great and all, but how do I get the pressure switch to work then?
Unread 16-02-2009, 22:48
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Originally Posted by star_lancer View Post
...how do I get the pressure switch to work then?
If you connect its pneumatic port to the high-pressure (120 PSI) part of your pneumatic piping, the pressure switch works without any further effort required on your part.
Prepare an appropriate length of servo ("PWM") cable by cutting the male (with pins) end off and leaving the female (with holes) end connected to the cable. Wire one of the pressure switch's terminals to the black wire of the cable and the other terminal to the white wire, leaving the red wire disconnected (and suitably insulated with electrical tape to prevent its 5 volt power from touching anything by accident). Plug the end of the cable into the DIGITAL I/O port on the Digital Sidecar that matches the port number you told the Compressor Open VI.
Air Compressor Question Jrocklz Pneumatics 4 17-01-2008 21:36
Air Compressor Wireing question Bochek General Forum 7 11-01-2007 21:34
Running just the compressor (was: free compressor) sciguy125 Pneumatics 15 06-02-2006 18:23
pic: Major CD47-Bot Extra Discussion 2 16-04-2003 13:49
compressor and light question... archiver 2001 5 24-06-2002 00:47
