Go to Post Ha, our 2009 robot's nickname was Sparky, for the same reason...we now have EXTRA fire extinguishers because of it ;P - Karibou [more]
Unread 16-02-2009, 12:32
3DWolf's Avatar
3DWolf 3DWolf is offline
Boots - Head Programmer / 3D
AKA: Jake
FRC #1502 (Technical Difficulties)
3DWolf is on a distinguished road
Send a message via AIM to 3DWolf Send a message via MSN to 3DWolf
Spike power problems
Getting dangerously close to ship!
We have 3 different parts of our robot that require motor power
Drive - Manip Loader - Manip Spitter
We're powering the loader through a spike because we don't need variable speed on it, and the drive and spitter are through victors.
The drive has one CIM on each side, the loader uses 2 CIMs with a toughbox, and the spitter uses 2 banebot motors.
The problem we're running into is when the loader hits a ball, there is a voltage drop and its popping the breaker in the spike - the breaker in the power distribution block is fine, but we got tired of blowing fuses and put auto resetting breakers in the spikes.
At first we found that the spikes were on the 40 amp section, so we moved them to the 20, then found that we had different wire gauges, and fixed that problem, but we're still popping the breakers.
We're kinda stumped - anyone have any thoughts
You can call it the programming teams fault, but we'll just force your arguments nil.
There are 10 kinds of people in the world -> Those who understand binary and those who don't.
WYSIWYG - In FIRST: Greatness
Jaguar and Spike Problems huskyrobotics Electrical 8 14-02-2009 08:56
Motor Power Problems team691 Robot Showcase 2 10-02-2009 00:26
Power Spike Questions WarLord Ryan General Forum 1 14-02-2008 16:51
Spike Problems doyler Programming 2 10-03-2005 20:20
Initial Power Spike archiver 2001 3 24-06-2002 00:42
