Go to Post It is a little known fact that Team 1114 is actually "General Motors Canada and Hogwarts Academy" The whole Niagara FIRST thing is just a cover to keep the magic arts concealed from us muggles. - dtengineering [more]
Thread Tools Rating: Thread Rating: 3 votes, 5.00 average. Display Modes
Unread 16-02-2009, 15:24
Plepel Plepel is offline
AKA: Chris
FRC #1877 (Gold Diggers)
Plepel is on a distinguished road
Labview Build Unsuccessful
I am trying to compile my code in labview, and when I click build, the window that pops ups says this:
LabVIEW prevented a file name collision during the build. Duplicate file names cannot be copied to the same destination. You can rename files as part of the build process to avoid name conflicts.
Then later it says:
The Build was unsuccessful.
Possible Reasons:
An error occurred while saving the following file:
C:\Program Files\National Instruments\LabVIEW 8.5\vi.lib\Robotics Library\NIFPGAInterface\AnalogTrigger\WriteConfigu ration.vi
Invoke Node in AB_Source_VI.lvclass:Close_Reference.vi->AB_Build.lvclass:Copy_Files.vi->AB_Application.lvclass:Copy_Files.vi->AB_Build.lvclass:Build.vi->AB_RTEXE.lvclass:Build.vi->AB_Build.lvclass:Build_from_Wizard.vi->AB_UI_FRAMEWORK.vi->AB_Item_OnDoProperties.vi->AB_Item_OnDoProperties.vi.ProxyCaller
<APPEND>
Method Name: <b>Save:Target Instrument</b>
Also, if I just try to run the program with the little arrow button, it cannot connect to the real time device.
I just updated all of the components, from the Driver Station to the cRio to Labview, and now these errors are happening.
I am using the exact same code that I was using an hour ago, and it worked then.
Thanks for any help, guys!
Unread 16-02-2009, 20:15
Re: Labview Build Unsuccessful
As a diagnostic, can you comment out the calls to the analog trigger and see if that allows for an interactive run as well as a build? Alternatively, you may just want to send all of your code into email support and we'll do the subsetting to see what library or what VIs are having issues being built.
Greg McKaskle
Unread 17-02-2009, 11:44
TDohse TDohse is offline
AKA: Thomas
no team (NI)
TDohse is an unknown quantity at this point
Here's something to try: Right click on the build specification and select Properties. Go to the "Additional Exclusions" category and make sure that "Modify project library after removing unused members" is not checked
Unread 17-02-2009, 14:01
AKA: Chris
Ok, so I found out that the errors that I was having before were related to the new update. It was applied incorrectly.
However, now it is applied right, and I can get the code to work with a soft run (the arrow like on the front panel.)
I cannot get it to build, however.
When I try, I get these errors:
"LabVIEW prevented a file name collision during the build. Duplicate file names cannot be copied to the same destination. You can rename files as part of the build process to avoid name conflicts."
"The Build was unsuccessful. Possible reasons:
C:\Program Files (x86)\National Instruments\LabVIEW 8.5\vi.lib\Robotics Library\NIFPGAInterface\Counter\ReadTimerConfigura tion.vi
Invoke Node in AB_Source_VI.lvclass:Close_Reference.vi->AB_Build.lvclass:Copy_Files.vi->AB_Application.lvclass:Copy_Files.vi->AB_Build.lvclass:Build.vi->AB_RTEXE.lvclass:Build.vi->AB_Engine_Build.vi->AB_Build_Invoke.vi->AB_Build_Invoke.vi.ProxyCaller
<APPEND>
Method Name: <b>Save:Target Instrument</b>"
And in the details pane, I get this:
"Visit the Request Support page at ni.com/ask to learn more about resolving this problem. Use the following information as a reference:
Error 6 occurred at AB_Source_VI.lvclass:Close_Reference.vi -> AB_Build.lvclass:Copy_Files.vi -> AB_Application.lvclass:Copy_Files.vi -> AB_Build.lvclass:Build.vi -> AB_RTEXE.lvclass:Build.vi -> AB_Engine_Build.vi -> AB_Build_Invoke.vi -> AB_Build_Invoke.vi.ProxyCaller
Possible reason(s):
LabVIEW: Generic file I/O error."
Thanks for all your help!
LabVIEW Woes: Build/Deploy time too long?! leftylink NI LabVIEW 7 27-01-2009 21:52
Students build SEGWAY in 3 months using Labview and the cRIO neutrino15 Programming 31 27-04-2008 22:08
Build/Mechanical teams after build and integration Bomberofdoom General Forum 1 02-02-2008 13:45
Any teams build two robots to practice with after build season. (6 weeks) GVDrummer General Forum 42 24-01-2008 21:34
