Go to Post It looks like you put a robot through a paper shredder. - Madwolvez [more]
Unread 16-02-2009, 17:22
Jack Gillespie's Avatar
Jack Gillespie Jack Gillespie is offline
FRC #5430 (Pirate Robolution)
Team Role: Teacher
Jack Gillespie is an unknown quantity at this point
Electrical Wiring on compressor
We can't not wire the compressor spike to the sidecar. The sidecar cable only goes one way. But it says that the wires need to be placed in the opposite direction. A B - but the black wire goes in first using the PWM cables.
On the spike it says B is the end on the cable, and the other two slots are blank. We don't know what to do, please help.
Unread 16-02-2009, 17:53
MPG's Avatar
MPG MPG is offline
Tutu Man
AKA: Michael
FRC #1259 (Paradigm Shift)
Team Role: Electrical
Rookie Year: 2007
MPG is an unknown quantity at this point
Re: Electrical Wiring on compressor
Could you be a little bit more clear with what you want help with. For me it is hard to understand
Thanks
Team Robot Names
2010 = Oswald
2009 = Black Magic
2008 = Barnaby Rover
2007 = Z
2006 = Dilbert
2005 = Oder
2004 = Gerry
Unread 16-02-2009, 17:55
eugenebrooks eugenebrooks is offline
AKA: Dr. Brooks
no team (WRRF)
eugenebrooks has a reputation beyond reputeeugenebrooks has a reputation beyond reputeeugenebrooks has a reputation beyond reputeeugenebrooks has a reputation beyond reputeeugenebrooks has a reputation beyond reputeeugenebrooks has a reputation beyond reputeeugenebrooks has a reputation beyond reputeeugenebrooks has a reputation beyond reputeeugenebrooks has a reputation beyond reputeeugenebrooks has a reputation beyond reputeeugenebrooks has a reputation beyond repute
The spike is used to control the compressor. It is wired
to the relay outputs of the digital side car, these have the
row of LEDs. Refer to page 28 of the data sheet, there is
a picture.
http://www.usfirst.org/uploadedFiles...s-Rev-0-5a.pdf
The black line on the pwm cable goes to the gnd pin.
On the spike, the black line goes to the B pin.
You should be sure to run the compressor in the right
direction with your software.
Unread 16-02-2009, 18:39
Team Role: Teacher
all of that is connected properly, at least as far as the diagram and black to black etc. The issue is likely going to be found to be a programming one - however, i'll describe the problem as it stands and get some help!
the spike has a light - it lights up. 12V incoming to the spike, none going out of the spike. When compressor is just hooked up to a battery, it does blow air. when hooked up to the spike, nothing.
We're stuck and can't figure it out - the programmer claims the code is set to enable compressor when buttons are pushed, but we push the buttons and nothing happens.
thanks in advance!
Unread 16-02-2009, 18:49
Russ Beavis Russ Beavis is offline
Russ Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond repute
You should check out the FRC Diagnostic Window application on Think Tank. It provides direct low-level access to all of the robot's I/O. You should be able to VERY quickly set the relay output states to confirm operation.
Also, I assume that your robot is enabled and the RSL light is properly lit?
Russ
Unread 16-02-2009, 19:12
Team Role: Teacher
Russ
1. Think Tank? FRC Diagnostic Window? We are clueless (rookies with no practice in labview, or programming robots)
2. RSL blinks - is that properly lit? flashes, no lights, flashes, no lights.
Unread 16-02-2009, 19:04
EricH's Avatar
EricH EricH is offline
New year, new team
FRC #1197 (Torbots)
That's probably it right there. Most teams (and I would suspect the default) configure it to be automatic on the pressure switch. If it's got a full tank already, it probably won't trigger no matter what you do until you drain the tanks.
Past teams:
2003-2007: FRC0330 BeachBots
2008: FRC1135 Shmoebotics
Solenoid Wiring and Compressor Help BurtGummer Electrical 16 17-02-2010 14:25
Electrical wiring TERTOLA Electrical 5 16-01-2008 16:22
Wiring the Compressor Jake M Pneumatics 4 24-01-2007 14:26
Basic Electrical Wiring Alienvin Electrical 2 18-01-2005 23:24
Wiring Compressor DakotaFox Electrical 3 05-02-2002 16:52
