Go to Post Although you will see lot's of people complain about parts (sometimes that includes me) all of us are held to the same constraints. That's what makes this so much fun. - Al Skierkiewicz [more]
Unread 16-02-2009, 22:19
dmlawrence dmlawrence is offline
MIT '14
FRC #1751 (Warriors)
dmlawrence is an unknown quantity at this point
Encoders not working
I am using the quadrature encoders that were included in the kit. I am experiencing an odd problem where the signal suddenly drops out soon after we start driving. I have attached a graph of the signal (after a low-pass filter) that shows the dropout very clearly. Here are some possible causes that have occurred to me
(1) The signal, which is passed through two solder joints and then a DB-25 connector, is somehow degraded to an unusable point.
(2) The camera processing is interfering with the encoder counting. (CPU usage is in the 80-90% range.)
(3) Something else?
Which of these is most likely? Any help will be most appreciated.
David
Team 1751
Unread 16-02-2009, 22:29
Re: Encoders not working
You don't give any details on how you are using the encoder, but there is a FAQ for LV that explains that the 4x option with averaging set to 1 will return a rate of 0 once the encoder moves very fast. This is not an issue with 2x encoders or when averaging is set to 2 or any other valid number. Also, the distance or count is fine, it is only the rate that has issues.
Greg McKaskle
Unread 16-02-2009, 23:01
MIT '14
Thanks for patrolling the forums during such a crucial time for teams! I had been using a separate averaging VI, not the encoder library's built-in averaging functionality (which was indeed set to 1 sample). Changing over to this averaging solved the problem. I'm glad this was such an easy problem to diagnose!
David
jaguar not working Bwood16 Motors 12 13-02-2009 13:22
cRio not working...? Jack Gillespie Programming 22 13-02-2009 13:07
p2 not working? Lone_Wolf92c Programming 5 22-02-2008 08:49
IR Board Not Working (But NOT Fried) itsme Electrical 2 18-02-2008 06:11
Encoders not changing... paulcd2000 Programming 28 18-02-2007 08:34
