Go to Post NASA rarely launches another rocket just so the programmers can see if they've fixed a bug. - Greg McKaskle [more]
Unread 17-03-2009, 18:32
Liu_yiang Liu_yiang is offline
AKA: Ian Pai
FRC #1245 (Shazbots)
Team Role: Electrical
Liu_yiang is an unknown quantity at this point
Re: URGENT(ish): Twitchy motors
Our robot didn't have a problem with twitching as much as it did with a constant speed, even though our readouts read zero. Our fix, strangely enough, was to copy and paste each individual part into a new program, with the exact same name. This also got rid of a nasty delay within our program.
Unread 19-02-2011, 12:00
Peragore's Avatar
Peragore Peragore is offline
CEO of Black Magic
AKA: Philip Mulford
FRC #3373 (Team Robohawk)
Rookie Year: 2011
Peragore is an unknown quantity at this point
While this is thread necro, we are getting a twitch problem whenever our robot is enabled. For some reason, we are not getting this twitch on the robotic arm. The robot motor will still twitch even when we have the motor in action. while there is no joystick input, we also get the twitch problem. Note that we have a working deadzone on the joysticks.
Code:
while (life){
  frcObsession = true;
  obs.ProgramAndObsess();
if (!life) life = true;
Unread 19-02-2011, 15:20
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Are you using Jaguars or Victors? Did you tell the software which one? What kind of drivebase do you have (how many motors, how many wheels, how is the motor power transmitted to the wheels, etc.)?
Unread 20-02-2011, 20:47
Kevin Wang's Avatar
Kevin Wang Kevin Wang is offline
Software Engineer, Webmaster
FRC #0694 (StuyPulse)
Rookie Year: 2010
Kevin Wang is an unknown quantity at this point
If the motor is controlled by a joystick input, then it may help to make sure that the joystick zeroes properly. This program helps in testing joystick axes and buttons:
http://www.softpedia.com/get/System/...k-Tester.shtml
Unread 22-02-2011, 14:27
frc2590's Avatar
frc2590 frc2590 is offline
Build Season is a Bit (Mu)ch
AKA: Whole Team
FRC #2590 (Nemesis)
Rookie Year: 2007
frc2590 is an unknown quantity at this point
Kendrick: try to change the throttle trim or also AKA calibration
Please visit our site for more info at: http://www.frc2590.org/
Motors, Motors, and More Motors 1033missions Motors 1 09-02-2006 18:46
Motors.. and more motors.. How many on your 2004 bot? OneAngryDaisy Motors 33 23-02-2004 00:46
Matching Drill Motors and Fischer-Price Motors archiver 2001 5 24-06-2002 00:51
Fisher Price Motors for Drill Motors archiver 2001 0 24-06-2002 00:22
F.P. Motors & gearbox for $12.50 Window Motors $19.50 archiver 2001 1 23-06-2002 23:05
