Go to Post It'll take some engineering, but you would have yourself something revoloutionary. Keep innovating! - Greg Perkins [more]
Unread 17-02-2009, 18:16
Patrick Chiang Patrick Chiang is offline
Programming
FRC #3070 (Team Pronto)
Patrick Chiang is a name known to allPatrick Chiang is a name known to allPatrick Chiang is a name known to allPatrick Chiang is a name known to allPatrick Chiang is a name known to allPatrick Chiang is a name known to all
Able to stream video in competition?
I heard that due to bandwidth issues, FIRST is restricting the ports on the router. Would we still be able to "see through" on Labview Dashboard during the competition?
Unread 17-02-2009, 20:10
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Re: Able to stream video in competition?
Dashboard data is part of the unfiltered communication from the robot to the DS. You'll be able to use it during competition.
However, even though the provided Dashboard project uses it, the live camera data is separate from the dashboard data, is blocked by the field network, and will be unavailable.
Unread 17-02-2009, 21:48
Programming
Ah. I see.
Then, can we not pass the video as data and compress it so that it gets to labview? Or would that be impractical?
Unread 17-02-2009, 23:17
popo308's Avatar
popo308 popo308 is offline
AKA: Brent
FRC #1625 (Winnovation)
popo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to all
Send a message via AIM to popo308
Originally Posted by Patrick Chiang View Post
Ah. I see.
I read somewhere you can include the camera data with the set user data vi (the allowed 984 bytes)
Can anyone confirm this?
If so how would you include the camera data? My team is also hoping to use it during a match...
Unread 18-02-2009, 01:29
nathanww nathanww is offline
Hacker
FRC #1678 (Citrus Circuits)
Rookie Year: 2007
nathanww is just really nicenathanww is just really nicenathanww is just really nicenathanww is just really nice
Yep, you have to rewrite the dashboard code but it's doable. As for compression, one strategy I was thinking of would be to simply translate a "high-level summary" back to the dashboard, something along the lines of "trailer here, robot here, wall over there", which is then reconstituted into an approximate visual representation by your dashboard. Depending on what you need it for, this could be blazingly fast
Get yer robot source code here!
Unread 19-02-2009, 23:44
Programming
I did some reading on this and I saw somewhere that it's actually quite doable with medium resolution and around 20fps. That will actually be extremely helpful if you are going to depend on your video to drive around. The only problem is going to be reprogramming your dashboard.
Unread 20-02-2009, 08:20
I think you should redo the math. The entire allowance is ~1kbytes per packet and fifty packets per second, so 50k/sec. From what I remember, the jpegs at medium are around 20k each.
Also keep in mind that the upload is going to chop the images up and recombine them. Your images to the dashboard are already lagged by perhaps 0.5 seconds, and these will be lagging even more. I'm not trying to talk you out of it, just making sure your expectations are not set too high.
Greg McKaskle
Dashboard stream Eldarion Control System 0 20-03-2006 02:26
Data stream Nine9cracker General Forum 4 20-01-2006 23:21
2004 competition video dpasquariello Championship Event 4 14-12-2004 22:41
info on Kick-off Video Stream MattK General Forum 1 02-01-2003 16:08
dashboard data stream archiver 2000 10 23-06-2002 22:56
