Go to Post Typed in "WaTeRgAmE" for the password and unfortunately it wasn't it. Bummer. - Kuhnahtt [more]
Unread 17-02-2009, 19:05
kgzak's Avatar
kgzak kgzak is offline
AKA: Kris
FRC #4392 (Decievers) FRC #2075 (Enigma)
kgzak is a splendid one to beholdkgzak is a splendid one to beholdkgzak is a splendid one to beholdkgzak is a splendid one to beholdkgzak is a splendid one to beholdkgzak is a splendid one to beholdkgzak is a splendid one to behold
Big problem
Our victors and spikes dont run when we run our code. the light also keeps blinking. we have tried re-imaging the cRIO multiple times and sometimes it works after we reimage but then stops the next time we want to run the code. Does anyone know why this is happening.
Unread 17-02-2009, 20:10
Jim E Jim E is offline
FRC #1523 (M.A.R.S.)
Jim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond repute
Re: Big problem
It sounds like you need to deploy your code upon start-up. Go to the NI and FIRST forum websites where it is discussed. You are running your code in memory. That means you need to download each time the cRio is powered up.
Team MARS = 1.523 AU from the SUN!
Jim E.
Unread 17-02-2009, 20:34
kgzak's Avatar
AKA: Kris
Re: Big problem
We do deploy the code every time we start up. We have not saved it to the cRIO yet. When i deploy the code i can see the voltage feedback of the pot but nothing else works
Unread 17-02-2009, 22:15
Re: Big problem
I think you are a little confused. There are differences between "deploying code to run on start-up"and deploying code every time you start the cRio. Learn how to do both.
As far as the problem you have, have you performed all of the mandatory updates to the cRio image? There was a Labview update about 2 weeks ago that requires anew cRio image.
Jim E.
Unread 18-02-2009, 13:08
kgzak's Avatar
AKA: Kris
Re: Big problem
We have all the updates and have re-imaged the cRIO. It worked before on and off but now it doesn't work at all. Could it be our sidecar is bad?
Unread 18-02-2009, 13:12
JesseK's Avatar
JesseK JesseK is online now
Expert Flybot Crasher
FRC #1885 (ILITE)
Re: Big problem
Check your digital sidecar connections. If you look in the manual for Victors, you'll find that blinking lights mean no PWM signal. This is independent of whatever code you do. If I remember correctly from our benchtop test over Thanksgiving Break, so long as the digital sidecar is powered, these lights should stop blinking.
GitHub
Unread 18-02-2009, 13:13
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Rookie Year: 2007
Re: Big problem
What light is blinking and at what rate?
What does your driver station say on it next to Status and Battery?
Unread 18-02-2009, 13:59
kgzak's Avatar
AKA: Kris
Re: Big problem
The drivers station says no code and the Victors are blinking like they aren't getting a signal from the PWM's.
Unread 18-02-2009, 14:01
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Rookie Year: 2007
Re: Big problem
It would appear that you have either no code or faulty code on your cRIO then.
Have you tried loading code since the last time you re-imaged or is the default image code on the robot?
Unread 18-02-2009, 14:21
kgzak's Avatar
AKA: Kris
Re: Big problem
We have reloaded the code. We always deploy the code from the computer because we have not saved it to the cRIO. Our code has run before and we have not changed it.
Unread 18-02-2009, 14:57
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Rookie Year: 2007
Re: Big problem
If the Driver's Station says "No Code" then the cRIO does not have working code running on it.
If you are running the code using the white arrow in Labview the computer must remain connected to the cRIO for the code to continue to run.
If after your code finishes downloading, the Driver's Station still says "No Code" I would try reimaging your cRIO and verifying that the Driver's Station connects properly to the cRIO with the default code.
Unread 18-02-2009, 15:19
kgzak's Avatar
AKA: Kris
Re: Big problem
But the driver station says no code but i can still read the feedback of the pot
Unread 18-02-2009, 15:21
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Re: Big problem
Where can you see this feedback?
If it says No code, it's a pretty clear sign that your main code is not running. Again, where do you see the voltage feedback?
Is this LabVIEW code or C++? If LabVIEW, how are you running it? You need to run the Basic Main VI in order for things to start properly. Make sure you aren't trying to run just the Autonomous Independent VI, for example.
Big problem! Need your help Tack610 Technical Discussion 12 04-02-2009 11:02
Big Problem w/new CMUcam! Darkelement Programming 4 30-01-2006 14:03
BIG Problem, please help me!! Srkasner FIRST Tech Challenge 2 11-01-2006 12:45
Big Big Problem Ronald_raygun Fundraising 23 04-10-2005 01:03
BIG Problem: Snowed In Joshua May General Forum 1 07-01-2005 16:52
