Go to Post Seating is limited. Be sure to apply deodorant and brush your teeth. - Wayne TenBrink [more]
Unread 18-02-2009, 11:39
Mike Mahar Mike Mahar is offline
FRC #0138
Mike Mahar will become famous soon enough
Quesion setting WPA encryption
There is a strict rule against any wi-fi transmitter except on the playing field. (How are they going to keep spectators from using their iPhones?)
They also want you to set the WPA encryption code in your game adapter. When I turn on my game adapter in the pits to set the WPA encryption code won't it start transmitting looking for wireless networks?
Unread 18-02-2009, 12:48
EHaskins EHaskins is offline
Needs to change his user title.
AKA: Eric Haskins
no team (CARD #6 (SCOE))
EHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond repute
Send a message via MSN to EHaskins
Re: Quesion setting WPA encryption
Personally I think trying to enforce non WiFi rules is pointless, so yes people will have laptops , phones , stadium networks, networks from nearby buildings, etc., I believe the intent of the rule to limit interference as much as possible by limiting the numerous team run networks which are in the pits every year.
As for the WPA configuration time, any transmissions you generate will be negligible compared to those of a network being actively used to transmit data.
Eric Haskins KC9JVH
Unread 18-02-2009, 12:52
Kevin Sevcik's Avatar
Kevin Sevcik Kevin Sevcik is online now
(Insert witty comment here)
FRC #0057 (The Leopards)
Rookie Year: 1998
It might, but at worst it's going to be hunting for the router you originally configured it to associate with. I'm not incredibly well versed in how exactly the game adapter works, but it's possible it just waits for a beacon frame from the router before it starts associating. At worst, it's going to send out probe frames to try to discover the router. You could have every robot in the regional doing this and it wouldn't make a noticeable dent in the 802.11n bandwidth.
The real problem would be teams running their routers and robots at the same time. Then you have a constant, fairly high rate datastream going. With extra routers all over the place for robots to possibly mistakenly associate with. And etc., etc.
EDIT: Again, a WiFi station/adapter/etc. isn't going to generate much traffic or interference, until it is associated with a network and actively doing something. So restrictions on actual wifi devices are mostly an abundance of caution. It's the restrictions on connecting to wireless networks and such that are going to be important.
Unread 18-02-2009, 13:16
Stuart's Avatar
Stuart Stuart is offline
#include coffee.h
FRC #1745 (P51- Mustangs)
Stuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond repute
Send a message via AIM to Stuart
I really dont know why they are baning 2.4gHz bands . . the field should be running on 5. I just dont see any sort of interference issues from these.( if 2.4 is too close than why is 2.1, cell phones. not to close?).
Proud mentor of Team #1745 the P-51 Mustangs
If at first it doesn't work, use a hammer.
If that doesn't work, use a bigger hammer.
Unread 18-02-2009, 13:19
petek's Avatar
petek petek is offline
What would Dave do?
AKA: Peter Kieselbach
FRC #3654 (Tech Tigers)
petek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond repute
Send a message via AIM to petek
Per Update 13:
Wireless communication clarification:
Regarding the wireless communication prohibition in Team Update 12, we’d like to clarify that general cell phone use is permitted. However, Wi-Fi use in the 2.4GHz or 5GHz bands is prohibited.
3G used by iPhone, etc. is <2.2GHz, but don't expect to use their Wi-Fi capabilities.
Though it may negatively impact some scouting plans, I agree with FIRST's decision to ensure that Wi-Fi is not an issue in the first season of the new control system; that's one hard-to-quantify variable that we don't need to deal with!
Pete Kieselbach
Unread 18-02-2009, 16:12
FRC #0138
I didn't say that it would interfere during the encryption process. I said that it might be against the rules. Don't be surprised if we have to unplug our game adapter power while in the pits.
Unread 18-02-2009, 17:33
petek's Avatar
What would Dave do?
The game adapter may search for networks, but the FMS won't connect to it unless its IP and WPA are valid for a team in the current match. As far as I've been told, we won't be concerned with the game adapters in the pits. We will not allow any routers to be powered up, however. Teams should leave their routers at home.
Pete Kieselbach
Manual Code / Encryption Key Levin571 General Forum 0 06-01-2007 11:31
Encryption Cracking Talk. Joe Johnson Rules/Strategy 4 08-01-2006 17:17
pdf encryption buss Programming 2 06-01-2005 23:11
