Go to Post If everyone else in the world is an idiot, you may need to recalibrate your idiotness scale. - GaryVoshol [more]
Unread 18-02-2009, 19:06
Pjohn1959's Avatar
Pjohn1959 Pjohn1959 is offline
AKA: Paul W. Johnson
Team Role: Teacher
Pjohn1959 has a reputation beyond reputePjohn1959 has a reputation beyond reputePjohn1959 has a reputation beyond reputePjohn1959 has a reputation beyond reputePjohn1959 has a reputation beyond reputePjohn1959 has a reputation beyond reputePjohn1959 has a reputation beyond reputePjohn1959 has a reputation beyond reputePjohn1959 has a reputation beyond reputePjohn1959 has a reputation beyond reputePjohn1959 has a reputation beyond repute
pic: 1429 New Crate
Unread 18-02-2009, 19:10
jason701802's Avatar
jason701802 jason701802 is offline
FRC #0753 (The High Desert Droids)
jason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant future
Re: pic: 1429 New Crate
Are you sure you got the weight right, if so how thick is the aluminum. The density of aluminum is about 0.1 lb/cu.in. It’s not clear how tall it is but I’ll assume 5’ (60”) for the box and 4’ (48”) on each side. That’s 4 x 48 x 60 = 11,520 sq.in. for the sides plus 2 x 48 x 48 = 4608 sq.in. for the top and bottom. Divide 90 lb by 0.1 lb/cu.in. and again by (11,520 + 4608) sq.in. and you get an average thickness of a little less than 1/16”. That’s without skids, connections or internal bracing. That is NOT going to made for a very robust crate.
Jason
Unread 18-02-2009, 19:13
EricLeifermann's Avatar
EricLeifermann EricLeifermann is offline
Taking some personal time
EricLeifermann has a reputation beyond reputeEricLeifermann has a reputation beyond reputeEricLeifermann has a reputation beyond reputeEricLeifermann has a reputation beyond reputeEricLeifermann has a reputation beyond reputeEricLeifermann has a reputation beyond reputeEricLeifermann has a reputation beyond reputeEricLeifermann has a reputation beyond reputeEricLeifermann has a reputation beyond reputeEricLeifermann has a reputation beyond reputeEricLeifermann has a reputation beyond repute
its aircraft aluminum, so I'm going to say that it is honeycomb aluminum which is very light and very strong... that gives you only weighing 90 lbs.
Unread 18-02-2009, 20:04
neoshaakti's Avatar
neoshaakti neoshaakti is offline
FRC #2554 (WarHawks)
neoshaakti is a splendid one to beholdneoshaakti is a splendid one to beholdneoshaakti is a splendid one to beholdneoshaakti is a splendid one to beholdneoshaakti is a splendid one to beholdneoshaakti is a splendid one to beholdneoshaakti is a splendid one to behold
Send a message via AIM to neoshaakti
Originally Posted by Pjohn1959 View Post
wow, blows the pants off our wooden crate...
looks very nice hahah
Unread 18-02-2009, 20:08
Smoores's Avatar
Smoores Smoores is offline
AKA: Steve Moore
FRC #2272 (Metalheads)
Team Role: Student
Rookie Year: 2007
Smoores will become famous soon enoughSmoores will become famous soon enough
If its honeycomb aluminum, I can see how that would be strong enough. It its just aircraft aluminum, that will not hold up.
Aviation in itself is not inherently dangerous. But to an even greater degree than the sea, it is terribly unforgiving of any carelessness, incapacity or neglect.
2007 Championship Highest Rookie Seed - Galileo
2007 CA Rookie All-Star
2007 CA Highest Rookie Seed
Unread 18-02-2009, 22:22
lynca's Avatar
lynca lynca is offline
Andrew Lynch
FRC #2587 (DiscoBots)
lynca has a reputation beyond reputelynca has a reputation beyond reputelynca has a reputation beyond reputelynca has a reputation beyond reputelynca has a reputation beyond reputelynca has a reputation beyond reputelynca has a reputation beyond reputelynca has a reputation beyond reputelynca has a reputation beyond reputelynca has a reputation beyond reputelynca has a reputation beyond repute
Send a message via AIM to lynca
Honeycomb Aluminum is pretty expensive could just be McMaster prices.
http://www.mcmaster.com/#8458k12/=nw8ee
Aircraft Aluminum is cheaper at the minimum thickness but definitely not as strong.
http://www.mcmaster.com/#1924t64/=nw9ad
What thickness are you guys using and do you have a local supplier ?
History: 624 - Cryptonite --> 118 - Robonauts --> 2158 - AusTIN CANS --> 2587 DiscoBots
Bio: Andrew Lynch "How I Work" ---- LinkedIn , Facebook, Twitter
Unread 19-02-2009, 17:18
Pjohn1959's Avatar
Team Role: Teacher
It is 1/8" plate aluminum 6061 T6. Maybe I am wrong on the weight. When I picked up one side, it didn't feel all that heavy. Since we don't have a scale, I was guessing.
pic: 987's New Crate KF987 Extra Discussion 12 22-01-2009 18:11
pic: Team 1429 Regional Chairman's award Pjohn1959 Extra Discussion 8 10-03-2008 13:50
pic: Team 1429 Robot Pjohn1959 Extra Discussion 3 04-03-2008 09:51
pic: Team 1429 in action Pjohn1959 Extra Discussion 1 09-03-2007 00:04
pic: 1429 Ramps deployed Pjohn1959 Robot Showcase 11 15-02-2007 15:09
