Go to Post When it comes to FIRST (you've all heard the cliche) -- we're all winners. When it comes to the competition: to the engineering design challenge, we're NOT all winners -- some solutions are better than others. - JVN [more]
Unread 18-02-2009, 23:18
Technic-R-C Technic-R-C is offline
FRC #2358
Technic-R-C is an unknown quantity at this point
Basic Framework
Hello,
I am currently trying to incorporate all of our LabView code into the basic framework FRC project. I have put all our teleoperated code into the Basic Robot Main vi. and the Autonomous mode in the Autonomous Independent.vi and then enabled the structure from false to true for autonomous mode. Next, I download the Basic Robot Main.vi with teleoperated mode onto the robot and everything worked while the driver station switch was set to teleoperated. However the problem occured when the driver station switch was changed to autonomous mode..... the autonomous code phase does not run at all even though the autonomous code was tested independently by downloading the autonomous independent.vi directly to the robot... Is there another vi or some kind of master compiling that I have to do in order to run the entire code and then be able to switch between autonomous and teleoperated?
Thank you,
Technic-R-C
P.S. The autonomous code being used is the one that came preloaded with the Basic Framework Project.
Basic Robot Framework JimC2550 Electrical 1 14-02-2009 21:09
CRio Framework Shadow_Cat NI LabVIEW 1 13-02-2009 21:18
Camera on basic framework Arcre NI LabVIEW 2 11-02-2009 04:17
FRC Framework Guide Jon236 FRC Control System 0 17-11-2008 18:18
Robot Framework lord Purity Pneumatics 3 21-01-2007 15:57
