Go to Post For our next exercise, we should define Beauty and Truth. :) - Taylor [more]
Unread 19-02-2009, 13:09
Shinigami2057 Shinigami2057 is offline
Slackware Is Your New God (Mentor)
AKA: Harry Bock
FRC #1350 (Rambots)
Shinigami2057 is just really niceShinigami2057 is just really niceShinigami2057 is just really niceShinigami2057 is just really niceShinigami2057 is just really nice
Using a GPIO pin for both input and output.
Our team would like to use an ultrasonic rangefinder that uses the signal pin for both input and output (ping control and echo are on the same data line).
How would you go about using WPILib to switch a GPIO pin between input and output? Specifically, I'd like to do something along the following lines:
Code:
 DigitalOutput ping(12);
 Counter echo(12);
 echo.SetSemiPeriodMode(true);
 ping.Pulse(pingPulseWidth);
 double range = echo.GetPeriod();
This is very easy to do with most microcontrollers, but I can't see an easy way to do this with WPILib. Any tips from the WPI guys?
One of the main causes of the fall of the Roman Empire was that, lacking zero, they had no way to indicate successful termination of their C programs.
AnalogChannel as both an accumulator AND a normal input? Jared Russell C/C++ 2 31-01-2009 10:14
Dashboard Analog Meters and GPIO? Geek_Girl Programming 1 17-12-2008 09:50
Analog pin output data 3DWolf Programming 3 22-01-2008 10:23
roll pin into output shaft m1k3 Kit & Additional Hardware 18 15-01-2008 16:18
using set screw or dowel pin/pin to hold on drill motor coupler thinggy Travis Covington Motors 1 04-02-2002 03:02
