Go to Post The robot uprising is coming for your chairs first, people. - bobbysq [more]
Unread 20-02-2009, 16:14
Pausert Pausert is offline
FRC #1727 (REX)
Team Role: Leadership
Rookie Year: 2007
Pausert is an unknown quantity at this point
Case Structures
I need to use a case structure that doesn't use a boolean. I know that if I wire another type of input to the case structure it will fit itself to the type, but is there any other way to change its input and see the cases associated with each type?
Unread 20-02-2009, 17:10
Re: Case Structures
Go ahead and hook up the string, number, or enum. Then click through the diagrams and using the menu items at the bottom you can choose some of the items, or you can type into the label. Be sure to look at examples or manuals to get a feel for the flexibility.
Greg McKaskle
Unread 08-03-2009, 13:01
Garii's Avatar
Garii Garii is offline
Registered Abuser
AKA: Jared Hankle
FRC #3044 (BE4)
Garii is an unknown quantity at this point
Send a message via AIM to Garii
Re: Case Structures
Cases are extremely versatile, all you have to do is wire something to the boolean case node and it will switch to what ever you wire it to. the only other things I'd like to add is that if your doing an array or something like that that the case doesn't always add all the variables available
-The Garii- aka Jared Hankle
Ballston Spa Labview Programmer
new team slogan-"Can I Get Some Linux With These Fries?"
Unread 14-03-2009, 21:51
Shivang1923 Shivang1923 is offline
I make robot go VROOM VROOM!
FRC #1923 (MidKnight Inventors)
Shivang1923 has a spectacular aura aboutShivang1923 has a spectacular aura about
Re: Case Structures
in that case, you right-click and select 'add case after' and it should create a new case with the next variable in the array
Unread 15-03-2009, 10:50
Re: Case Structures
Just to keep the terminology clean, cases/switches don't do arrays at all. The string and enum have a set of values they support, but the thing wired must be a scalar, not an array.
In the case of the enum, it may be useful to use the popup for creating all cases at once, otherwise use the Add before or Add after.
Greg McKaskle
paper: FIRST Drive Trains and Structures Madison Extra Discussion 18 04-12-2007 17:37
Green light Case Lablabla Technical Discussion 9 16-01-2007 21:53
Compiler has troubles with structures? steven114 Programming 1 21-02-2006 18:28
Question: Carrying Case UIDzero Technical Discussion 10 10-11-2003 14:35
Bone structures x_cat_SHAUN 3D Animation and Competition 1 11-02-2003 18:57
