Go to Post This is a solemn reminder of how fast time goes by with the blink of an eye, that if you don't run to catch up with it, it will catch up with you and sweep you away. - Ken Leung [more]
Unread 20-02-2009, 22:20
Mr_D_Mentor's Avatar
Mr_D_Mentor Mr_D_Mentor is offline
AKA: Frank D'Anna
FRC #5856 (The Bullbots)
Mr_D_Mentor is on a distinguished road
Rule G22
At the Suffield Shake Down scrimmage the officials added a requirement that the super cell that was exchanged had to be exactly opposite the position on the rack where the empty cell was placed. I would like to know if any other scrimmages had this rule imposed. Also, do you think it's a real rule?
8th year mentor
Bullbots, First Team #5856
The Nuts & Bolts of Fury, FIRST Team #3525
Team MAX, FIRST Team #1071
Unread 21-02-2009, 01:18
EricH's Avatar
EricH EricH is offline
New year, new team
FRC #1197 (Torbots)
Re: Rule G22
I can't find anything saying that it's an official rule. However, it is reasonable for it to be a guideline to make it easier for the refs. If you aren't sure, Q&A. Now. This is something that could bite teams during Week 1. It will affect play, at least for a bit. Right now, it's not enforceable by the rules. Either the rules have to change (1 update chance to do that) or the requirement must leave.
Past teams:
2003-2007: FRC0330 BeachBots
2008: FRC1135 Shmoebotics
Unread 22-02-2009, 19:27
AKA: Frank D'Anna
Re: Rule G22
Thanks for confirming my suspicion. I'd like to ask First, but I'm still waiting for my account to be activated.
My main concern is that if this becomes an official rule, it will put unnecessary stress on the PS in the corner who only has 20 seconds to decide what to do with the potential game changing super cells.
8th year mentor
Unread 22-02-2009, 20:36
engunneer's Avatar
engunneer engunneer is offline
Alumni turned Mentor
AKA: Branden Gunn
FRC #4761
Rookie Year: 1996
engunneer has a reputation beyond reputeengunneer has a reputation beyond reputeengunneer has a reputation beyond reputeengunneer has a reputation beyond reputeengunneer has a reputation beyond reputeengunneer has a reputation beyond reputeengunneer has a reputation beyond reputeengunneer has a reputation beyond reputeengunneer has a reputation beyond reputeengunneer has a reputation beyond reputeengunneer has a reputation beyond repute
Re: Rule G22
I'm not sure why this is a concern. The super cell is on the rack. A robot delivers an empty cell. The PS puts the EC on the rack, grabs the SC right next to it, and then enters the SC into play. It should be a 2-3 second operation, tops.
Putting the EC on the rack opposite the SC is an easy way to verify that the SC was legally traded.
Student FRC23 (1996-1999), Mentor FRC246 (2000), Mentor FRC1318 (2007-2009), Mentor FRC93 (2011), Mentor FRC2151 (2012), Mentor FRC23 (2013), Mentor FRC4761 (2014-2017)
1998 - National Chairman's Award and Woodie Flowers Award (FRC23, Mike Bastoni ) | 2007 - PNW SF (488, 1595) | 2008 - Oregon RCA - Seattle #2 Seed, SF (488, 1696) | 2009 - Oregon #1 Seed, Winners (1983, 2635) - Seattle SF (945, 2865) - Galileo #2 Seed, SF (973, 25) | 2012 Midwest F (111, 71) | 2014 RIDE Winners (78, 125), Inspector - NEU #24, QF (3479, 3958) - NECMP #35 | 2015 Reading #11, SF (1058, 190), Inspector - RIDE #17, QF(4055, 5494), Inspector - NECMP #57 | 2016 Reading #4, SF (133, 4474), DCA, Inspector - Ride #22, SF (1735, 2067), Creativity, Inspector - NECMP #48, RCA - Archimedes
Unread 22-02-2009, 23:09
EricH's Avatar
New year, new team
FRC #1197 (Torbots)
Re: Rule G22
2-3 seconds, IF that EC comes in in the last 20 seconds.
That's what I'm thinking happened: the officials thought that this would be an easy way to confirm that the appropriate number of Super Cells were in play from a given Fueling Station. However, in the process, they created a new rule. That isn't appropriate. You gotta put something like that in an update!
I would encourage any team who is penalized for throwing the wrong Super Cell at competitions (not throwing before the appropriate time, throwing the wrong cell) to challenge the ruling. In, of course, a graciously professional manner. If the refs can't show you the rule, then according to the GDC, they can't give you a penalty (though cards may be in order--also not called for here.) This is unless Tuesday's update contains a new restriction.
Past teams:
Unread 23-02-2009, 09:34
EricLeifermann's Avatar
EricLeifermann EricLeifermann is online now
Taking some personal time
EricLeifermann has a reputation beyond reputeEricLeifermann has a reputation beyond reputeEricLeifermann has a reputation beyond reputeEricLeifermann has a reputation beyond reputeEricLeifermann has a reputation beyond reputeEricLeifermann has a reputation beyond reputeEricLeifermann has a reputation beyond reputeEricLeifermann has a reputation beyond reputeEricLeifermann has a reputation beyond reputeEricLeifermann has a reputation beyond reputeEricLeifermann has a reputation beyond repute
Re: Rule G22
Its fairly obvious that if there is one EC and one SC left on the rack that someone has swapped them, why do they need to be right next to each other? As long as there are at least 2 game pieces on the rack there should be no problem whether or not you swapped a EC on the left side for the SC on the right side...
Unread 23-02-2009, 10:02
EricH's Avatar
New year, new team
FRC #1197 (Torbots)
Re: Rule G22
Exactly! But, for whatever reason, officials chose to use a rule that isn't a rule for this. Good practice for the PS? Maybe. But if it isn't in the rules, it isn't in the rules.
Past teams:
Unread 23-02-2009, 14:48
ReaperGoat's Avatar
ReaperGoat ReaperGoat is offline
Volunteer
AKA: Ruth Toomey
FRC #0319
ReaperGoat has much to be proud ofReaperGoat has much to be proud ofReaperGoat has much to be proud ofReaperGoat has much to be proud ofReaperGoat has much to be proud ofReaperGoat has much to be proud ofReaperGoat has much to be proud ofReaperGoat has much to be proud of
Send a message via AIM to ReaperGoat
Re: Rule G22
Team 1735 stopped by the Suffield Shakedown to watch a few matches and see how the game played out, and I distinctly remember one match where they gave a penalty for taking the wrong SC, only to rescind it a couple minutes later after finding out that someone had switched the balls!
I really hope that this doesn't become an official rule, because it hypothetically becomes very easy for anyone to move the balls (on accident or not) in the commotion during the reset (unless officials are vigilant in keeping an eye on it)
Team 1735 Student (2006), Mentor (2008, 2009)
Team 190 mentor/mascot (2007, 2015, 2016)
Team 319 Mentor (2016-present)
FIRST Volunteer (2009-2016)
Unread 23-02-2009, 15:48
bigbeezy's Avatar
bigbeezy bigbeezy is offline
AKA: Bryan
FRC #2338 (Gear it Forward)
Team Role: Coach
bigbeezy is a splendid one to beholdbigbeezy is a splendid one to beholdbigbeezy is a splendid one to beholdbigbeezy is a splendid one to beholdbigbeezy is a splendid one to beholdbigbeezy is a splendid one to beholdbigbeezy is a splendid one to beholdbigbeezy is a splendid one to behold
Send a message via AIM to bigbeezy
Re: Rule G22
i dont really see how this is a problem. and I do believe i heard this rule at kickoff where inorder to use a supercell there had to b an emptycell on the poll adjacent to it.
And i dont see how there could be confusion with moving supercells. IF empty cell on rack next to supercell AND time is less than 20 seconds THEN supercell can enter play OTHERWISE it stays on rack.
Why would this not be a rule? I mean theres 4 supercells on ur alliance, 2 per station. if you have an empty cell then u can switch. I mean it would be very confusing if this wern't a rule cause alliances and refs would have to be keeping track of empty/super cells from different parts of the field.
EDIT: O i guess i misunderstood what happened. but once you put an EC on the rack y would u move it? and if something like that did happen i guess the human player should have the awareness to put it back before the game is over.
Unread 23-02-2009, 15:55
EricH's Avatar
New year, new team
FRC #1197 (Torbots)
Re: Rule G22
I said this last year, but it bears repeating: I don't care what whoever says at Kickoff, if it isn't in the rules, it isn't in the rules. If it isn't in the rules, it isn't a rule. If it's enforced as a rule, EVERY team that gets penalized has grounds for a challenge. And they've only got 1 update to make it a rule/not a rule.
Past teams:
Unread 23-02-2009, 16:12
bigbeezy's Avatar
AKA: Bryan
Team Role: Coach
Re: Rule G22
i know but seeing as i havn't been apart of build season and havn't read the rules as thoroughly as usual i just figured it was in there. my bad
but still dont see how this is a big deal
Team 1592 Bionic Tigers -- Driver 2005-2008
Winner - Florida Regional 2005
Finalist - Newton Division 2007
Winner - Colorado Regional 2008
Florida State University - BS Mechanical Engineering
Team 2338 Gear it Forward -- Mentor/Drive Coach 2013-Present
Winner - Wisconsin Regional 2013
Chairman's Award - Midwest Regional 2015
Winner - Archimedes Sub-Division 2015
Chairman's Award - Midwest Regional 2016
Unread 23-02-2009, 16:30
ReaperGoat's Avatar
Volunteer
AKA: Ruth Toomey
FRC #0319
Re: Rule G22
so, the way that they were calling these penalties at the Shakedown, they were 20pts a pop. for just grabbing the "wrong" Super Cell.
Unread 23-02-2009, 16:47
bigbeezy's Avatar
AKA: Bryan
Team Role: Coach
Re: Rule G22
IMHO thats no different then a driver accidentally picking up 2 EC's with the robot. Part of that person's job is to not do that, so if they get a penalty for not paying attention then they get a penalty.
now if they were nice they would let you be able to fix it before the match was over, like if theres an EC on one rack and u do grab through the wrong one but then fix it before the match is over then it wouldnt b penalized. but thats if they are nice, and if they actually make this a rule.
AlexD744 AlexD744 is offline
FRC #0744 (744 Shark Attack)
AlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond repute
Re: Rule G22
I think it mentioned this in the video, however, I haven't seen a rule.
  #15   Spotlight this post!
Unread 23-02-2009, 16:59
EricH's Avatar
New year, new team
FRC #1197 (Torbots)
Re: Rule G22
Were there any challenges?
Past teams:
Overdrive <G22> poll: yea or nay? Alan Anderson Rules/Strategy 55 12-03-2008 09:49
Rule G22 needs to be changed Dave Flowerday Rules/Strategy 122 10-03-2008 22:55
G22 Direction of Traffic Hilarity Kevin Sevcik Rules/Strategy 16 17-01-2008 22:30
problems with G22 JMH Electrical 2 19-01-2005 20:52
