recieve data from cRIO
We have a custom dashboard (written in C# .net or VB .net) and it is supposed to receive the packets coming from the DS on port 1165 of type UDP. we have the cRIO running the following program based off the dashboard data example:
Code:
void RobotMain()//so it executes even if disabled
Dashboard &dashboard = m_ds->GetDashboardPacker();
while (true)
dashboard.Printf("It's been %f seconds, according to the FPGA.\n", GetClock());
dashboard.Printf("451!|distance=2|flywheel=%f|!451\n", 1);//our custom packet of data
dashboardDataFormat.PackAndSend();
Wait(0.02);
here is the .net code in C#: Code:
/*init function*/
UdpClient cRIO = new UdpClient();
cRIO.Bind("10.4.51.5",1165);
/*end init*/
/*in the start button click*/
IPEndPoint ipend = new IPEndPoint(IPAddress.Any, 1165);
this.textBox1.Text = cRIO.Recieve(ref ipend);
//*end button*/
Re: recieve data from cRIO
Here is the applicable code from my dashboard. It uses async calls so its a little more complicated.
Code:
Sub BeginGetDataAsync() Implements IDashboardClient.BeginGetDataAsync
_listening = True
_client = New UdpClient(DS_TO_PC_LOCAL_PORT)
_client.BeginReceive(AddressOf Me.GetDataAsync, Nothing)
End Sub
Sub GetDataAsync(ByVal result As IAsyncResult) Implements IDashboardClient.GetDataAsync
Try
Dim endPoint As IPEndPoint = Nothing
Dim bytes = _client.EndReceive(result, endPoint)
ParseBytes(bytes)
Catch ex As Exception
Throw
Finally
If Listening Then
End If
End Try
End Sub
Thanks! now we can see something, it looks like ?M? for each packet, and changes to variations of that, ?p? ?r? ??? etc... changing the encoding changes the ? to other chars, but it looks weird (wiresharks verifies that our custom packet works, and looks normal there)
You are awesome.. that's Visual Basic?
Unfourtunatly, yes(I am a C# person). But fortunatly, I know Visual Basic
Code:
Dim reader As New BinaryReader(New MemoryStream(data))
reader.ReadBytes(26) 'Skip the automatically sent data (team number, battery, DS in/outs, etc.)
SequenceNumber = reader.ReadByte()
Dim printedString = New String(Text.Encoding.ASCII.GetChars(reader.ReadBytes(reader.EReadUInt32())))
Me.PrintedString.Add(printedString)
Dim errorString = New String(Text.Encoding.ASCII.GetChars(reader.ReadBytes(reader.EReadUInt32())))
Me.ErrorStrings.Add(errorString)
Dim dataSize = reader.EReadUInt32()
Dim userData As Byte() = reader.ReadBytes(dataSize)
Code:
Imports System.IO
Imports System.ComponentModel
Imports System.Collections.ObjectModel
Imports System.Runtime.CompilerServices
Public Module BinaryReaderExtensions
<Extension()> _
Public Function EReadUInt32(ByVal reader As BinaryReader) As UInt32
Dim bytes = reader.ReadBytes(4)
Return bytes(0) * 255 ^ 3 + bytes(1) * 255 ^ 2 + bytes(2) * 255 ^ 1 + bytes(3)
End Function
<Extension()> _
Public Function EReadUInt16(ByVal reader As BinaryReader) As UInt16
Dim bytes = reader.ReadBytes(2)
Return bytes(0) * 255 ^ 1 + bytes(1)
End Function
End Module
Thanks, but i figured it out:
(in C#.net just to irritate you VB bigot) Code:
buffer= client.Receive...
string endresult = "";
foreach (byte databit in buffer)
endresult+=((buffer==0)?"":((char)databit).ToString());//I love () to make sure thigs execute as i want (as well as ; semicolins;)
textBox1.Text+="\n"+endresult;
?hs\0546d\0jos\0MYDATAHERE\0jsfjnn\0 and it cut off after the \0 (or null (buffer = 0) (Nothing for you VB bigot)) i just had to set a breakpoint, see the data, and realize what was happening (the string was being chopped up!); |
Something very useful for feedback is the ability to write to the LCD of your DriverStation: http://thinktank.wpi.edu/article/144
All that is great, as long as you have a laptop around.
| Data delay between Crio and DS | Tom Line | NI LabVIEW | 9 | 17-02-2009 08:40 |
| Capture Data from the cRio | goodsky | Programming | 2 | 13-01-2009 21:27 |
| Sending data from RC to OI | Nathan | Programming | 7 | 03-02-2008 22:32 |
| Did we recieve MS Front Page from FIRST | Mr.G | Website Design/Showcase | 2 | 28-01-2006 15:12 |
| Programming Vex Starter Kit To Recieve From Serial Port | firetrap | FIRST Tech Challenge | 0 | 26-09-2005 17:27 |
