Go to Post In my line of work, we affectionately refer to this approach as "Seagull Engineering". Why? Because we swoop in, flap around making a lot of noise and commotion, leave a big mess of "stuff" behind and then fly off. - billbo911 [more]
Unread 22-02-2009, 17:14
Charlie_A Charlie_A is offline
FRC #1721 (Tidal Force)
Charlie_A is an unknown quantity at this point
Vex Encoders
Hi all,
My team is a little behind in the traction control area. So I have been coding away on an encoder based method. I seem to have run into a problem, i'm not sure how to set up the Vex encoder in the Open Encoder VI.
Any help would be much appreciated
Thanks,
Charlie
Unread 22-02-2009, 17:34
Mark McLeod's Avatar
Mark McLeod Mark McLeod is online now
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
Re: Vex Encoders
Here's an example:
Unread 22-02-2009, 19:26
Re: Vex Encoders
Hmmm, it looks as though I have the old, nonquadrature model, any suggestions?
Unread 22-02-2009, 21:28
Just Itinerant
Re: Vex Encoders
You can use what I showed with a single channel encoder.
Get rid of the second DIO and just wire the single DIO to both A & B inputs.
Without quadrature the encoder will only count up as it turns in whatever direction, so you do have to be careful to trust it's output only when you are sure you are moving forward or backward.
While sitting still it will probably start counting as the robot vibrates.
You might want to program in a reset when you begin a move forward or backward.
Unread 23-02-2009, 16:17
Re: Vex Encoders
Thanks so much!
Encoders..... manderson5192 Programming 4 07-02-2008 10:10
Vex encoders/Interrupts buddy.smith Programming 9 08-02-2007 08:01
Vex navigation with ultrasonic and encoders GlennGraham Electrical 4 13-01-2006 12:58
VEX Optical Shaft encoders in FRC sanddrag FIRST Tech Challenge 8 04-10-2005 07:52
encoders stephenthe1 Programming 61 09-02-2005 15:05
