Go to Post Sweeeet swerve drive - Andy Baker [more]
Unread 23-02-2009, 15:20
mahmosh's Avatar
mahmosh mahmosh is offline
FRC #1946
mahmosh is an unknown quantity at this point
programming axis for motor
our team is working to improve the program so we ask u how to program the axis for jaguar ... and is there -xaxis ?! to use it left or right
Unread 23-02-2009, 22:03
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Re: programming axis for motor
Are you programming using LabVIEW, or are you writing C++ in Workbench? The details differ for each.
[Caution: I am posting without benefit of LabVIEW running on my computer, so I might not get the details exactly right in what follows.]
In LabVIEW, you use a Motor Open VI to specify which PWM output and what kind of speed controller you're using. The output of that VI is a device reference that you feed to a Motor Set VI, and later to a Motor Close. The Motor Set takes a number from -1 to 1 in order to control the motor direction and speed.
Similarly, you use a Joystick Open VI to specify which USB port's joystick you want to read. Its device reference goes to a Joystick Get Axis VI, and later to a Joystick Close. The Joystick Get Axis also takes an input defining which axis you want to use (yes, the X axis is the left-right one), and provides a numeric output from -1 to 1 representing the position of the joystick.
The output of the Joystick Get Axis VI goes to the input of the Motor Set VI.
[Again, caution: I don't have practice with C++ and the WPI library this year, so my description might not get the details here right either.]
Using C++, the ideas are the same, but the implementation is completely different. You instantiate a Motor object, either by setting a Motor *pointer to a new() or by statically declaring a Motor variable, and similarly instantiate a Joystick object. Use Joystick.GetAxis() to read the joystick position, and use Motor.Set() to set the motor speed.
Unread 24-02-2009, 06:43
byteit101's Avatar
byteit101 byteit101 is offline
WPILib maintainer (WPI)
AKA: Patrick Plenefisch
no team (The Cat Attack (Formerly))
byteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of light
C++ would be
Joystick stick(1);//joystick1
stick.GetX();
Bubble Wrap: programmers rewards
Watchdog.Kill();
printf("Watchdog is Dead, Celebrate!");
How to make a self aware robot: while (∞) cout<<(sqrt(-∞)/-0);
Previously FRC 451 (The Cat Attack)
Now part of the class of 2016 at WPI & helping on WPILib
Unread 24-02-2009, 07:45
mahmosh's Avatar
FRC #1946
i am using windriver
thanks i have done
programing motor with axis frcchile Programming 1 16-02-2009 08:30
Which axis for accelerometer? bitsoglass NI LabVIEW 1 23-01-2009 17:42
Programming the axis camera...... programmr C/C++ 10 11-01-2009 12:23
Axis Camera Programming in Labview Striker_27 NI LabVIEW 10 09-01-2009 19:19
Getting feedback from Axis Camera?? *programming in C++* Straberrie Programming 3 01-01-2009 22:39
