Go to Post Maybe we should put one of those advisory signs: "Don't try this at home ... or at Robotics competitions" - Franchesca [more]
Go Back   Chief Delphi > Technical > Kit & Additional Hardware
Unread 23-02-2009, 22:46
neoshaakti's Avatar
neoshaakti neoshaakti is offline
FRC #2554 (WarHawks)
neoshaakti is a splendid one to beholdneoshaakti is a splendid one to beholdneoshaakti is a splendid one to beholdneoshaakti is a splendid one to beholdneoshaakti is a splendid one to beholdneoshaakti is a splendid one to beholdneoshaakti is a splendid one to behold
Send a message via AIM to neoshaakti
CIM Hub
I found a CIM hub on Andymark.biz but it's out of stock
http://andymark.biz/am-0320.html
Any suggestions of a place I can get something similar?
The application for this Hub is to direct drive a roller (3" ID PVC tube) using a CIM
Thank you
Unread 23-02-2009, 22:53
Ice Berg's Avatar
Ice Berg Ice Berg is offline
Seth Berg
AKA: Seth Berg
FRC #0694 (Stuy Pulse)
Rookie Year: 2007
Ice Berg is a splendid one to beholdIce Berg is a splendid one to beholdIce Berg is a splendid one to beholdIce Berg is a splendid one to beholdIce Berg is a splendid one to beholdIce Berg is a splendid one to beholdIce Berg is a splendid one to beholdIce Berg is a splendid one to behold
Send a message via AIM to Ice Berg
Re: CIM Hub
Hey,
I'm from team 694, I worked with you guys a bit at the NY regional last year on some motor issues. If you have something drawn up or have an idea of something that you want machined, PM and we could machine it down at our lab.
-Seth
Mens et Manus
Unread 23-02-2009, 23:00
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
Re: CIM Hub
You could easily buy a 250 hub from AM and drill it to 8mm and broach a key way in it. That's what we did the week before AM came out with the new hub.
Unread 23-02-2009, 23:05
vivek16's Avatar
vivek16 vivek16 is offline
Whoa! college pilot.
AKA: vivek
FRC #2264 (trojan robotics)
Rookie Year: 2007
vivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond repute
Send a message via AIM to vivek16 Send a message via MSN to vivek16
Re: CIM Hub
Our intake is a belt driven CIM drive (16 tooth drive gear and 56 driven gear). We didn't use a keyway but just put a set screw in the keyway slot and another set screw 90 degrees away on the shaft. It seems to work ok. You definitely don't want to do this for higher torques but it's not horrible for a low torque application.
-Vivek
p.s. My point is that you don't need to use a keyway as long as you're careful.
"we don't build robots, we build people"
Unread 24-02-2009, 09:46
Brandon Holley's Avatar
Brandon Holley Brandon Holley is offline
Chase perfection. Catch excellence.
AKA: Let's bring CD back to the way it used to be
FRC #0125 (NU-TRONs, Team #11 Alumni (GO MORT))
Brandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond repute
Send a message via AIM to Brandon Holley
Re: CIM Hub
-Vivek
Of all the lessons I've learned in FIRST...the one I've learned the hardest is never trust a set screw...
MORT (Team 11) '01-'05 :
-2005 New Jersey Regional Chairman's Award Winners
-2013 MORT Hall of Fame Inductee
NUTRONs (Team 125) '05-???
2007 Boston Regional Winners
2008 & 2009 Boston Regional Driving Tomorrow's Technology Award
2010 Boston Regional Creativity Award
2011 Bayou Regional Finalists, Innovation in Control Award, Boston Regional Finalists, Industrial Design Award
2012 New York City Regional Winners, Boston Regional Finalists, IRI Mentor of the Year
2013 Orlando Regional Finalists, Industrial Design Award, Boston Regional Winners, Pine Tree Regional Finalists
2014 Rhode Island District Winners, Excellence in Engineering Award, Northeastern University District Winners, Industrial Design Award, Pine Tree District Chairman's Award, Pine Tree District Winners
2015 South Florida Regional Chairman's Award, NU District Winners, NEDCMP Industrial Design Award, Hopper Division Finalists, Hopper/Newton Gracious Professionalism Award
Unread 24-02-2009, 11:54
Andy Baker's Avatar Woodie Flowers Award
Andy Baker Andy Baker is offline
President, AndyMark, Inc.
FRC #3940 (CyberTooth)
Rookie Year: 1998
Andy Baker has a reputation beyond reputeAndy Baker has a reputation beyond reputeAndy Baker has a reputation beyond reputeAndy Baker has a reputation beyond reputeAndy Baker has a reputation beyond reputeAndy Baker has a reputation beyond reputeAndy Baker has a reputation beyond reputeAndy Baker has a reputation beyond reputeAndy Baker has a reputation beyond reputeAndy Baker has a reputation beyond reputeAndy Baker has a reputation beyond repute
Send a message via AIM to Andy Baker
Re: CIM Hub
AndyMark now has more of the 8mm Key Hubs.
Sincerely,
Andy
Unread 24-02-2009, 12:47
Daniel_LaFleur's Avatar
Daniel_LaFleur Daniel_LaFleur is offline
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Daniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond repute
Send a message via MSN to Daniel_LaFleur
Re: CIM Hub
I'll only trust a set screw if I can dimple the shaft first.
___________________
"We are not now that strength which in old days moved earth and heaven; that which we are, we are;
One equal temper of heroic hearts, Made weak by time and fate, but strong in will
To strive, to seek, to find, and not to yield. "
- Tennyson, Ulysses
Unread 24-02-2009, 13:28
Uberbots's Avatar
Uberbots Uberbots is offline
Mad Programmer
AKA: Billy Sisson
FRC #1124 (ÜberBots)
Uberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond repute
Re: CIM Hub
QFT
our 2007 arm joint had a sprocket attached by a set screw on the motor output shaft... needless to say we had a lot of slipping that year.
A few of my favorite numbers:
175 176 177 195 230 558 716 1024 1071 1592 1784 1816
RPI 2012
BREAKAWAY
Unread 24-02-2009, 15:27
vivek16's Avatar
AKA: vivek
Rookie Year: 2007
Re: CIM Hub
The set screw does fall into the keyway slot and has shaft collars on either side.
As long as we can keep it the screw tight, we should be ok. We don't have the machining capabilities to broach a hole in a timing belt pulley.
-Vivek
Unread 24-02-2009, 16:17
Bill Beatty Bill Beatty is offline
#0071 (Team Hammond)
Bill Beatty has a reputation beyond reputeBill Beatty has a reputation beyond reputeBill Beatty has a reputation beyond reputeBill Beatty has a reputation beyond reputeBill Beatty has a reputation beyond reputeBill Beatty has a reputation beyond reputeBill Beatty has a reputation beyond reputeBill Beatty has a reputation beyond reputeBill Beatty has a reputation beyond reputeBill Beatty has a reputation beyond reputeBill Beatty has a reputation beyond repute
Re: CIM Hub
You really don't need a machine shop to broach the 2mm keyway. A broach and 8mm collar is not very expensive. We gently rap the broach with a hammer to drive it through the bore. Using a hammer seems to work better than pressing the broach, particularly in steel.
Mr. Bill
Sprocket with hub or without? Vikesrock Technical Discussion 5 15-01-2008 01:14
your thoughts on the FP CIM/2.5 CIM motor drive setup versus 2 2.5 CIM motors waialua359 Motors 11 14-12-2007 04:29
Hub for Wheel attachments Lavapicker Kit & Additional Hardware 5 09-01-2007 19:27
Re: Connecting hub sprockets to shafts archiver 2001 1 24-06-2002 00:20
Connecting hub sprockets to shafts archiver 2001 18 24-06-2002 00:04
