Go to Post You inspire your way. I'll inspire my way. - Andrew Schreiber [more]
Unread 01-03-2009, 19:50
psychomonkey psychomonkey is offline
Mr. February
AKA: Seth Rhodes
FRC #1592 (Bionic Tigers)
psychomonkey is an unknown quantity at this point
Question Autonomous selection from dashboard
Hello everybody,
I would like to be able to have an enumerated constant on the dashboard to switch between the different autonomous codes that I have. I am using a case structure to flip between codes. I can hook an enumerated constant directly to the case structure, but I would like to make it a global variable so as to reference it from the dashboard. Is it even possible to reference autonomous independent vi to the dashboard in the basic framework?
In a time... When the greatest comeback occured... There was... MR. FEBRUARY!!!
Switching to/from autonomous mode RDD Programming 6 12-02-2007 16:14
Setting Autonomous Settings from OI Tom Saxton Programming 15 27-03-2005 11:45
Setting Autonomous Settings from OI Tom Saxton Control System 4 14-03-2005 22:33
Weird Output from Dashboard Port Ian W. Programming 9 06-03-2004 21:33
Autonomous Code From Experience EbonySeraphim Programming 7 14-03-2003 21:56
