Re: possible solution to the static problem
our team found out that our robot was a very efficient vann-de-graff generator ( we have super-fuzzy paint rollers spinning against PVC!!!, oh and di i mention, there are two, one at the top, and one at the bottom, with surgical tubin in between...)
i've been shocked many times, and at the PDX regional, several robots would drive across the field, hit the wall, discharge the static and die... this led to some teams mot doing at all as well as they could have... also, the feild was set up on top of big rubber mats, on top of an ice rink... (i don't know why they didn't just use the ice!!! I hope this whole fiasco is figured out before championships!!!!! -Z |
But good luck to everyone! keehun Team 2502 |
Dave,
I was up in Milwaukee last night and they reported using the static spray and had no problems that they could pinpoint as a static issue during practice. Milwaukee is on concrete and it was pretty cold up there so the heat is on. |
Sorry if this is a repeat I didn't have alot of time to post. We have begun using dryer sheets to wipe both the wheels and any lexan and/or plastic on the robot after every match. Thus far it has worked quite well to reduce the amount of static being carried by the robot. We have added it to our list of procedures after the match and only takes a couple of students a minute or two to do.
Just my $.02 Pat |
| Solution to camera problem | techkid7 | Programming | 1 | 12-01-2009 08:42 |
| Onan Generator Control Problem - RC as solution? | RyanN | Electrical | 8 | 01-12-2008 16:45 |
| pic: Banebots carrier plates problem & solution | Elgin Clock | Extra Discussion | 14 | 10-03-2007 07:50 |
