Go to Post It's good to learn from experience. It's better to learn from somebody else's experience. - Jay TenBrink [more]
Unread 03-03-2009, 00:55
Dave Flowerday Dave Flowerday is offline
Software Engineer
VRC #0111 (Wildstang)
Rookie Year: 1995
Dave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond repute
Virtual Driver Station
I started working on this last week before the Midwest Regional, and lately I've seen some discussion on CD about the possibility of doing something like this so I figured it might be a good time to post a preliminary version. There's a lot more I'd like to do with it but it's usable now for some basic things. This is a preliminary/preview version only at this point.
So what is it? It's a program that runs on your Windows PC and emulates (most of) the FRC Driver Station. It will connect up to a robot and send commands to it just like a real DS, including reading values from joysticks on your PC. Right now it simply reads joysticks in the order it finds them, though one of the first things I plan to enhance is to allow you to assign a particular joystick to a particular DS port (this is important to my team as we use ports 1 and 3 but not 2). Additionally you can control the driver station digital inputs (analog inputs yet to be implemented) by using keys on the keyboard. Finally, it will also send data to the Dashboard computer. See the readme.txt file inside the .ZIP for more information.
As far as usability, I make no guarantees at this point. Our drivers drove 111's practice robot for a half hour or so using this software and couldn't tell a difference between this and the real thing. However, if you use different joysticks than we do it's possible it might not map them correctly. If you find this to be the case, please let me know.
A word of caution: since this software can control the robot, it could be dangerous if not used correctly. I've implemented it to start up in a disabled state, and require a 2-key sequence to enable it. Even still, do not use this software while anyone is near the robot. Make sure everyone is a safe distance away, and make sure you are able to disconnect the network cable from your computer if something doesn't work right.
Hopefully some people will find some use in this. Given all the problems with the real driver stations, I think it could be useful (we have 2 DSes and both have failed in a different way). If you only have 1 DS and need to send it in for repairs, it's possible you might be able to use this to practice with in the meantime.
Attached below is a picture of what it looks like while running and the .ZIP file containing the program. Please see the readme.txt file contained within the program for more details. Again, with a limited amount of hardware to test with I can't make any guarantees that it will work for you. Also, again I will say to please be cautious when using it and make sure no one is nearby when you run it. Thanks.
Driver Station S.O.S. M. Gildner Electrical 15 28-11-2009 19:35
Driver Station dnrobotics11 Control System 2 18-02-2009 21:35
Inputs on Driver Station z2daj C/C++ 8 16-02-2009 04:12
Dead Driver Station? tdeprince FRC Control System 3 12-02-2009 12:14
Need Driver Station dekker120 FRC Control System 2 02-02-2009 12:59
