Go to Post Don't just build a robot; build up your community. - Pat Arnold [more]
Unread 03-03-2009, 14:24
Otaku's Avatar
Otaku Otaku is offline
Where'd my wrench go?
AKA: Michael Baker
FRC #0675 (Tech High Phantom Robotics)
Otaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond repute
Send a message via AIM to Otaku Send a message via MSN to Otaku
non-'FRC legal' control systems?
Before I get any flak for this -- no, 675 isn't planning on building our own control system.
My senior project involves motors and I'm already somewhat familiar with robot control systems, but if I can't get permission to use an old IFI FRC control system for my project, I'll need to figure out how to take the values from the two pots in a joystick and turn them into PWM signals. And as cheaply as possible.
Essentially, I need to build a system that will be light, cheap, effective and robust for use in a wheelchair I am designing and building that is based off of some of 675's previous chassis designs.
so... potentiometer value to PWM, so I can feed it into a vic or jag into a motor. Suggestions, other than FRC control systems?
I would just use the IFI Control System or the NI cRIO, but they're both quite expensive, so...
"The [Otaku] is a simple creature." "Indeed. I cease to function when removed from a mill."
diversified systems at FRC Kickoff-NH www.divsys.com General Forum 1 02-01-2008 19:34
Motor Control Systems Astronouth7303 Programming 3 05-04-2005 19:35
Control Systems dbeck103 General Forum 2 30-09-2003 12:49
Control Systems archiver 2000 1 23-06-2002 22:15
It's Raining Control Systems CaptainPlaid Technical Discussion 6 24-03-2002 15:32
