Go to Post I don't mind being odd...I like to - listen - to Dean Kamen's speeches. They make sense. I don't get to listen to a lot of sense in the world, just a lot of noise. - JaneYoung [more]
Unread 06-03-2009, 09:48
Ben87 Ben87 is offline
FRC #0087 (Diablo)
Team Role: Driver
Ben87 is a jewel in the roughBen87 is a jewel in the roughBen87 is a jewel in the rough
Why Hasn't first gone Brushless?
Hello all,
First post here, So I'll introduce myself. My name is Ben White of team 87- if any of you were at the granite state regional or Philadelphia regional- i was the tall black guy on drive team.. Kind of hard to miss me. I am team 87's hardware man and have a question
My question to you is why FIRST has not gone to brushless motors and speed controllers over the CIM motors, 884's and jaguars?
Brushless motors are loads more efficient, make more torque, and can be purchased with different winding configurations for different kv and Kt values.(rpm per volt and torque per amp).
For any of you that run hobby grade RC cars, you have seen the advantages of brushless motors. you get longer runtime, more power and the motors are less temperamental when under load.
What I would like to see is that first legalizes brushless motors and speed controls... yes they are expensive but they have their advantages.
Unread 06-03-2009, 09:57
dlavery's Avatar
dlavery dlavery is offline
Curmudgeon
FRC #0116 (Epsilon Delta)
Rookie Year: 1996
dlavery has a reputation beyond reputedlavery has a reputation beyond reputedlavery has a reputation beyond reputedlavery has a reputation beyond reputedlavery has a reputation beyond reputedlavery has a reputation beyond reputedlavery has a reputation beyond reputedlavery has a reputation beyond reputedlavery has a reputation beyond reputedlavery has a reputation beyond reputedlavery has a reputation beyond repute
Re: Why Hasn't first gone Brushless?
Originally Posted by Ben87 View Post
yes they are expensive...
You just provided the answer to your own question.
-dave
"I know what you're thinking, punk," hissed Wordy Harry to his new editor, "you're thinking, 'Did he use six superfluous adjectives or only five?' - and to tell the truth, I forgot myself in all this excitement; but being as this is English, the most powerful language in the world, whose subtle nuances will blow your head clean off, you've got to ask yourself one question: 'Do I feel loquacious?' - well do you, punk?"
- Stuart Vasepuru, 2006 Bulwer-Lytton Fiction Contest
My OTHER CAR is still on Mars!!!
Unread 06-03-2009, 10:01
EricVanWyk EricVanWyk is offline
Rookie Year: 2000
EricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond repute
Send a message via AIM to EricVanWyk
Assuming that the rules allowed it, what motor driver and motors would you use? Do you have any specific parts to recommend? Along Dave's lines, could you also list the $$$ factor?
The powers that be at FIRST are reasonable, but they respond much better to "It would be cool to do X, and here is how we can reasonably achieve it" than "Why aren't you doing X?".
Unread 06-03-2009, 10:00
Lil' Lavery Lil' Lavery is offline
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Lil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond repute
Send a message via AIM to Lil' Lavery
I'm going to go out on a limb and say... cost.
FIRST would have to provide the motors to all the teams in the KoP.
The 2.5" CIMs are approximately 337 Watt motors, and cost $28 individually from Banebots. This brushless motor with a peak wattage of 350 costs nearly 3x as much.
Edit: beat to it
Being correct doesn't mean you don't have to explain yourself.
Unread 06-03-2009, 10:05
Greg Peshek Greg Peshek is offline
FLL #2054
Rookie Year: 2011
Greg Peshek is a name known to allGreg Peshek is a name known to allGreg Peshek is a name known to allGreg Peshek is a name known to allGreg Peshek is a name known to allGreg Peshek is a name known to all
Well if they just legalized them as in let teams use them without putting them in kits... you would have teams with ridiculous advantages over any team who can't afford the price tag on even a small brushless motor. An Axi-2208 which is a comparable replacement for a motor a tough smaller than like the Banebots.. is about $75. Not to mention the price of the speed controllers.
And FIRST can't afford to put them in the kits. I'm sure they can pick up CIMs surplus for under $10.. nowhere can you pick up brushless cheap for surplus so that's why they can't just include it in the kit. They cost a lot in general.
Unread 06-03-2009, 10:19
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
I see the Lavery family suffers from cost consciousness (as does the Forbes family)
Efficiency is great, if you can afford it. Usually we can't.
Unread 06-03-2009, 12:03
Alex698's Avatar
Alex698 Alex698 is offline
Sparky
FRC #2449 (Out of Orbit Robotics)
Alex698 is a jewel in the roughAlex698 is a jewel in the roughAlex698 is a jewel in the rough
Send a message via AIM to Alex698
FIRST may go brushless for a water game.
Eat, Sleep, Build Robots
Unread 06-03-2009, 12:08
Kingofl337's Avatar
Kingofl337 Kingofl337 is offline
You didn't see anything....
AKA: Adam
FRC #0501 (Power Knights)
Rookie Year: 1998
Kingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond repute
Send a message via Yahoo to Kingofl337
If that were true we would have brushless motors this year.
FIRST Team 501 PowerKnights - Mentor
FIRST Team 40 Checkmate - Mentor Alum
FIRST Team 146 Blue Lightning - Alumni
Unread 06-03-2009, 12:18
CJmango's Avatar
CJmango CJmango is offline
AKA: Christopher Jones
CJmango is an unknown quantity at this point
Send a message via AIM to CJmango
Yeah, and with the fairly high weight limit and short matches, there's really no design crunch to move to a more expensive/efficient motor. Although you're right, FIRST doesn't even allow teams to use brush motors that don't come in the kit; if they let teams buy comparable brushless you would start to see even more of a gap between well to do and not so well to do teams.
You make a very interesting point about the motor coefficients, too. Moving to brusheless opens up a lot of design parameters to which students don't currently have much exposure. Picking motors based on their performance and fit with your design becomes much more complicated and interesting.
Unread 06-03-2009, 12:53
Gdeaver Gdeaver is offline
FRC #1640
Gdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond repute
The jags and victors will work with most any brushed DC motor that is with in the power specs. With ECM motors the controller needs to be designed for the motor and that means more money and less flexibility. First can include any 12volt brushed motor they want to. With the NI C-Rio and the availability of CAN and LIN busses, First could include a brushless motor in the future. The automotive industry is going toward intelligent modules. In the future First could find a deal on surplus window, light, seat position, moon roof, rear hatch or other modules that use ECM motors. Then it would be up to Ni and WPI to write the interface for us.
Unread 06-03-2009, 13:45
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
Luminary Micro makes reference motor controller kits for brushless, stepper, and AC induction motors. If FIRST wanted to foray into other motor types, I'm sure they could work it out.
I'd rather get stepper motors before FIRST went brushless.
Unread 06-03-2009, 14:35
writchie writchie is offline
Engineering Mentor
AKA: Wally Ritchie
FRC #2152 (Team Daytona)
Team Role: Coach
Rookie Year: 2007
writchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond repute
I agree. This would be a better next step
Unread 06-03-2009, 16:09
Kingofl337's Avatar
AKA: Adam
Rookie Year: 1998
Some stepper motors would be pretty sweat. Holding toque for a stepper motor is really nice..
Unread 06-03-2009, 16:17
Rick TYler Rick TYler is offline
A VEX GUy WIth A STicky SHift KEy
VRC #0010 (Exothermic Robotics)
Rick TYler has a reputation beyond reputeRick TYler has a reputation beyond reputeRick TYler has a reputation beyond reputeRick TYler has a reputation beyond reputeRick TYler has a reputation beyond reputeRick TYler has a reputation beyond reputeRick TYler has a reputation beyond reputeRick TYler has a reputation beyond reputeRick TYler has a reputation beyond reputeRick TYler has a reputation beyond reputeRick TYler has a reputation beyond repute
All our robots would look better in those little Canadian hats, with or without stepper motors. http://en.wikipedia.org/wiki/Tuque
(EDIT: Kingof1337 made an innocent typing error that generated something even better. I had no intention to make fun of anyone. My screen name is an example of my own ability to miptyse something.)
(EDITED AGAIN: It's an Internet rule - predating the WWW - that all criticisms of someone else's grammar or splelling should contain a similar misteak.)
Exothermic Robotics Club, Venturing Crew 2036
VRC 10A, 10B, 10D, 10Q, 10V, 10X, 10Z, and 575
  #15   Spotlight this post!
Unread 06-03-2009, 16:41
dlavery's Avatar
Curmudgeon
Rookie Year: 1996
Originally Posted by Rick TYler View Post
All our robots would like (look) better in those little Canadian hats, with or without stepper motors. http://en.wikipedia.org/wiki/Tuque
As is your response.
-dave
Why we love FIRST!!! nevereverregret General Forum 9 11-12-2008 07:21
pic: 614 hasn't tipped yet. EHaskins Extra Discussion 3 09-10-2006 16:33
Why FIRST is important... Joe Johnson General Forum 7 23-05-2006 14:22
If anyone hasn't noticed.... archiver 2000 5 23-06-2002 22:41
So you do FIRST..... Why? Kate Leach General Forum 44 02-07-2001 08:55
