Re: Pinning Long Robots
we have found a trick that works for our robot, if you notice our robot has between 75% and 80% of its weight on the back two wheels, this essentially makes us a wide robot. (we are narrow) when we are hit the front of the robot pivots into the turn, which rotates the robot in a circle, pulling the trailer away from the pining robot. we can increase our turn by utilizing our turret. our robots turret is a large part of the robots weight, and by accelerating it we turn. (35lb turret with a 27.5" diameter provides a lot of rotational inertia) we designed our turret to act like a gyroscope.
After attending both the NJ and NYC regionals, and driving 25 matches between them, i found the best way to not get pinned is to drive backwards. Our robot was in the long configuration, and since the trailer is about the same width as our robot, i never had a problem getting out of getting pinned. Driving backwards lets you turn way easier, as the trailer helps spin you around. Another great way to not get pinned is to have a robot on your alliance pin the other alliances robots (thank you team 1796).
[quote=pacoliketaco;834345] Our robot was in the long configuration, and since the trailer is about the same width as our robot, i never had a problem getting out of getting pinned. QUOTE]
Just wait til' Atlanta, you will see the amazing power of 2543 Titan bot. i do believe from all the matches ive seen, they are the powerhouse to watch out for. ![]() |
There are defensive bots out there that are just plain incredible. |
as a long robot ifound it easy to pin and out manuvere wide robots backing up truly does help
Here are the Kettering videos IKE was talking about: http://www.adambots.com/wiki/FIRST_2009_Videos Watch our robot (The yellow power dumper). As the driver I used this little maneuver to get out of a lot of defense. |
| Best Pinning Robots You've Seen so Far | Akash Rastogi | Technical Discussion | 22 | 03-03-2009 18:44 |
| Is pinning opposing robots trailers allowed? | spiffyspleen | Rules/Strategy | 22 | 05-01-2009 16:47 |
| Pinning a Mechanism | Rob2713g | Technical Discussion | 5 | 30-01-2008 13:11 |
| Clarification on Pinning | Stu Bloom | Rules/Strategy | 2 | 15-03-2006 05:07 |
| Ramming/ Pinning | f22flyboy | General Forum | 21 | 07-03-2003 20:39 |
