Go to Post We moved-ish mostly, in a direction or two. - Siri [more]
Unread 09-03-2009, 15:52
P.Svilans P.Svilans is offline
FRC #2994
P.Svilans is an unknown quantity at this point
Pressure Switch Problem?
Hi,
My team right now is having problems with the pressure switch...basically what happens is that we hook it up and the whole thing screws up. I'm guessing that it's not hooked up right (does something like that disable the whole control system?), or some wacky code that's running under the level I'm working with (somewhere deep down in the core classes?).
I'm pretty sure it's the hook up, but I'm just wondering if any other teams experienced any problems of the sort?
It's my schools first year in FIRST...
P.
Pressure Switch R.C. Pneumatics 3 24-04-2008 01:54
pressure switch M.Jesus Pneumatics 1 15-02-2008 17:36
[OCCRA]: Problem with the compressor, pressure switch, or Bosch relay. BrittanyV OCCRA 3 16-10-2006 15:42
pressure switch Michael Long Pneumatics 1 11-02-2003 11:21
pressure switch piconysm Technical Discussion 5 14-02-2002 23:15
