Go to Post FIRST loves robot heroes. - Rick TYler [more]
Unread 09-03-2009, 17:01
mutantblond mutantblond is offline
FRC #2523
mutantblond is an unknown quantity at this point
Power for Driver Station
Will there be 120V power available for the driver station? i know it says so in the rules, but just wanted to make sure since it had to be battery-powered last year.
thanks!
Unread 09-03-2009, 17:02
GBIT's Avatar
GBIT GBIT is offline
Lexantologist/Team Lead
AKA: Jared
FRC #0811 (Cardinals)
Team Role: Mechanical
GBIT is just really niceGBIT is just really niceGBIT is just really niceGBIT is just really niceGBIT is just really nice
Send a message via AIM to GBIT
Re: Power for Driver Station
Do you mean on the field or in the pit?
On the field it gets power through the comp port.
In the pit there are outlets.
-Mentor-
-WPI '13-
-Former Team Lead-
-Past Driver-
Unread 09-03-2009, 17:18
thefro526's Avatar
thefro526 thefro526 is offline
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
thefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond repute
Send a message via AIM to thefro526 Send a message via MSN to thefro526
thanks!
The OI from last year didn't have to battery powered, it's always gotten power from the field.
This year the Driver's Station get's it's power through the competition port. When you go onto the field it'll be a black cable with a 9 pin connector. Make sure it's tight when you put it in because that's the last thing you want coming out in a match.
-Dustin Benedict
2005-2012 - Student & Mentor FRC 816
2012-2014 - Technical Mentor, 2014 Drive Coach FRC 341
Current - Mentor FRC 2729, FRC 708
Unread 09-03-2009, 21:50
Kristian Calhoun's Avatar
Kristian Calhoun Kristian Calhoun is offline
Celebrating 20 years of 25
FRC #0025 (Raider Robotix)
Kristian Calhoun has a reputation beyond reputeKristian Calhoun has a reputation beyond reputeKristian Calhoun has a reputation beyond reputeKristian Calhoun has a reputation beyond reputeKristian Calhoun has a reputation beyond reputeKristian Calhoun has a reputation beyond reputeKristian Calhoun has a reputation beyond reputeKristian Calhoun has a reputation beyond reputeKristian Calhoun has a reputation beyond reputeKristian Calhoun has a reputation beyond reputeKristian Calhoun has a reputation beyond repute
Send a message via AIM to Kristian Calhoun
QFT.
Teams, please make sure that the competition cable is firmly plugged into the Driver Station and keep the slack in the wire out of the way your drivers. There have been instances where drivers have bumped into the extra wire of the competition cable that they had hanging below the player station's shelf and inadvertently disconnected their Driver Stations, leaving their robot inoperable for the remainder of the match. Such an occurrence does not count as a field error; it is YOUR responsibility to check. This is especially important because the stock screws on the competition cable are too short to thread into the holes on the DS.
Raider Robotix: Home | Twitter | Facebook | Instagram
Brunswick Eruption: Home | Twitter | Facebook
Unread 09-03-2009, 23:34
RyanCahoon's Avatar
RyanCahoon RyanCahoon is offline
Disassembling my prior presumptions
FRC #0766 (M-A Bears)
Rookie Year: 2007
RyanCahoon has a reputation beyond reputeRyanCahoon has a reputation beyond reputeRyanCahoon has a reputation beyond reputeRyanCahoon has a reputation beyond reputeRyanCahoon has a reputation beyond reputeRyanCahoon has a reputation beyond reputeRyanCahoon has a reputation beyond reputeRyanCahoon has a reputation beyond reputeRyanCahoon has a reputation beyond reputeRyanCahoon has a reputation beyond reputeRyanCahoon has a reputation beyond repute
According to the rules:
Originally Posted by R81
Please note that AC power will not be available at the playing field
Originally Posted by R83
Nothing can be connected to the power connector on the Driver Station during a MATCH.
--Ryan
FRC 2046, 2007-2008, Student member
FRC 1708, 2009-2012, College mentor; 2013-2014, Mentor
FRC 766, 2015-, Mentor
Unread 09-03-2009, 23:37
dani190 dani190 is offline
AKA: Dani
FRC #2185 (RoboRams)
Team Role: Leadership
Rookie Year: 2007
dani190 is a splendid one to beholddani190 is a splendid one to beholddani190 is a splendid one to beholddani190 is a splendid one to beholddani190 is a splendid one to beholddani190 is a splendid one to beholddani190 is a splendid one to behold
Send a message via MSN to dani190
Originally Posted by Kristian Calhoun View Post
QFT.
screws to short...
does this mean we should screw on 2 of those extenders included in the kit?
that way the thing screws into the driver station?
Unread 10-03-2009, 00:30
Mike Schreiber's Avatar
Mike Schreiber Mike Schreiber is offline
FRC #0067 (The HOT Team)
Mike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond repute
For teams who have competed in the semifinals or above and who have not been told to go back to the pit between elimination matches (such as we were in the quarters), how can you power your robot while on the side of the field? For example if you need power to reset, test, or fix features of your robot since the new system needs an AC power source for the controls? Is this available or is there another way to power the controls without being on the field or plugging into a wall? Or is there an outlet available for teams to tether up? I don't know a whole deal about the new system, so please feel free to correct me if I have anything wrong.
Mike Schreiber
Kettering University ('09-'13) University of Michigan ('14-'18?)
FLL ('01-'02), FRC Team 27 ('06-'09), Team 397 ('10), Team 3450/314 ('11), Team 67 ('14-'??)
Unread 10-03-2009, 00:36
Eugene Fang's Avatar
Eugene Fang Eugene Fang is offline
The Blue Alliance
Rookie Year: 2000
Eugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond repute
Yeah, I was wondering about this too, since last year's OI could get power directly from the RC, but this year it does not seem to be the case.
Thanks for any information!
Eugene Fang
2010 Silicon Valley Regional Dean's List Finalist
Various FLL Teams - Student (2000-2006), Mentor (2007-2010)
FRC Team 604 - Student (2007-2010), Mentor/Remote Advisor (2011-2015)
FRC Team 1323 - Mentor/Remote Advisor (2011-2014)
The Blue Alliance | TBA GameDay | TBA Android App
Unread 10-03-2009, 00:38
big1boom big1boom is offline
Chains=Fun
FRC #2022 (Titan Robotics)
Rookie Year: 2007
big1boom is a glorious beacon of lightbig1boom is a glorious beacon of lightbig1boom is a glorious beacon of lightbig1boom is a glorious beacon of lightbig1boom is a glorious beacon of lightbig1boom is a glorious beacon of light
Take the power from the Wireless bridge, and plug it into the drivers station, tethered.
Unread 10-03-2009, 00:42
Mr. Lim Mr. Lim is offline
AKA: Mr. Lim
Rookie Year: 1998
Mr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond repute
This was an issue for us at FLR. We actually had to roll our robot and controls to the scorer's table to get power to tether and run our robot. However I think we were only allowed to do this because we were also helping to diagnose a possible field issue during the finals round. I doubt that in the quarters and semis teams would have been allowed to simply setup at the scorers table whenever they please.
We're looking into rigging up an assembly to run the DS from a battery for GTR.
In life, what you give, you keep. What you fail to give, you lose forever...
Unread 10-03-2009, 00:44
The Blue Alliance
Rookie Year: 2000
Thanks for the quick reply. Just for clarification, is that what you just did or was that the specified procedure? I don't mean to imply anything negative. I just never saw that anywhere.
Thanks
Eugene Fang
Unread 10-03-2009, 00:55
Chains=Fun
Rookie Year: 2007
Thats what we did.
Our alliance took our timeout and we reprogrammed the robot on the field at Midwest.
Unread 10-03-2009, 08:33
merybar's Avatar
merybar merybar is offline
AKA: Matt
FRC #0894 (Chargers Robotics)
merybar is a glorious beacon of lightmerybar is a glorious beacon of lightmerybar is a glorious beacon of lightmerybar is a glorious beacon of lightmerybar is a glorious beacon of light
Send a message via AIM to merybar
What we did was we hooked up a 12 volt battery to a ac adapter, and put an anderson quick connect on the other side. It worked great on the field for quick resets and charging our tanks and such. The lead inspector at our event told us that he wasnt exactly for sure what is legal and advised. He also said that knowing that tanks must charged by the compressor through the robot, that he had not a clue how we should be powering the DS. Therefore we were allowed to power it in that way. He said he would be in contact with first, so hopefully we will get that answer soon.
Team 894 Chargers Robotics
Unread 10-03-2009, 10:54
esquared's Avatar
esquared esquared is offline
Keeps saying 3-2-1-Rush...
AKA: Angry Eric
no team (Volunteer!)
Team Role: Mascot
esquared has a reputation beyond reputeesquared has a reputation beyond reputeesquared has a reputation beyond reputeesquared has a reputation beyond reputeesquared has a reputation beyond reputeesquared has a reputation beyond reputeesquared has a reputation beyond reputeesquared has a reputation beyond reputeesquared has a reputation beyond reputeesquared has a reputation beyond reputeesquared has a reputation beyond repute
  1. Take a spare AC adapter with the appropriate DC barrel connector for the DS (doesn't have to be the right voltage), cut the wire.
  2. Strip and tin the loose wire ends.
  3. With a multimeter, verify which wire connects to the inside of the barrel, mark this with red electrical tape.
  4. Connect this new cable to the power distribution board with a 20A breaker
  5. Enjoy your robot-powered DS
I gave this to another team in the finals at FLR so they could do a quick reprogram, and would have done so again for team 188 but it was faster to have you guys grab the AC adapter while we went over what could be wrong on the robot. If you tie up/safely attach the DC cord, you could keep it wherever you disconnect the bridge ethernet so it's easy to swap both cables when you need a quick fix.
--Eric
Last edited by esquared : 10-03-2009 at 10:54. Reason: AC, DC, whats the difference really?
  #15   Spotlight this post!
Unread 10-03-2009, 11:53
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
We used a 9v battery. It should last somewhere around an hour (but we haven't measured it, or used it that much). Should be plenty for a few emergency uses.
Driver Station S.O.S. M. Gildner Electrical 15 28-11-2009 19:35
Driver Station for Autonomous shrimp Control System 5 03-03-2009 17:05
Driver Station dnrobotics11 Control System 2 18-02-2009 21:35
Driver Station Power at the competition. Robo640 FRC Control System 3 13-02-2009 16:59
Reading battery power on Driver station. Digmaster Electrical 8 31-01-2009 20:09
