Go to Post Dean's said it before, and it's been repeated many times, but it clearly hasn't sunk in yet, so I'll say really loudly. FIRST is not a science fair! - Karthik [more]
Unread 09-03-2009, 20:07
BurtGummer BurtGummer is offline
Electrical/Mechanical/Programming
FRC #3020
BurtGummer will become famous soon enoughBurtGummer will become famous soon enough
Timing belt size
Just a quick question, what size is the timing belt and the sprockets that go with it (the ones from the kit)? I need to order a few from McMaster just in case, but I can't find their tooth size and such.
Thanks!
Unread 09-03-2009, 20:14
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Rookie Year: 2007
Re: Timing belt size
They are 5mm pitch sprockets. The small ones are 16 tooth 9mm wide sprockets. The medium ones are 32 teeth and 15mm wide. The large one is 56 teeth and 15mm wide.
There were 3 belts in the kit all also 5mm pitch. There are two 535mm belts, one 9mm wide and one 15mm wide. The other belt is 900mm long and 15mm wide.
Unread 09-03-2009, 20:15
FRC #3020
Is there a teeth per inch measurement? Thanks soo much for your help!
EDIT: Nevermind, missed the pitch you already stated. Thanks alot!
EDIT2: Also, what are the shaft diameters on the CIMs this year? We have to replace an old CIM is why I ask, and we won;t be able to get the current timing belt pulley off of it, hence why we are ordering more.
Unread 09-03-2009, 20:26
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Rookie Year: 2007
The CIM motors have an 8mm shaft. 8mm is also very close to 5/16" if that helps.
Unread 10-03-2009, 00:03
kurttruk820 kurttruk820 is offline
AKA: Kurt Aschenbeck
FRC #2177 (Robettes)
Rookie Year: 2007
kurttruk820 is just really nicekurttruk820 is just really nicekurttruk820 is just really nicekurttruk820 is just really nice
Send a message via AIM to kurttruk820
Burt, if you have a few days to spare I'd recommend going to SDP-SI for timing pulleys (www.sdp-si.com). Their selection of GT2 & HTD pulleys beats the pants off McMaster, and they're quite a bit cheaper. We've been using their polycarb w/ aluminum insert pulleys on our shooter for the past month with zero problems.
And as an FYI, most curved-profile belts and pulleys are compatible, so an HTD, GT, or GT2 pulley with work with the 5mm pitch belt provided in the KOP.
Unread 13-03-2009, 15:47
Jared Russell's Avatar
Jared Russell Jared Russell is offline
Taking a year (mostly) off
FRC #0254 (The Cheesy Poofs), FRC #0341 (Miss Daisy)
Jared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond repute
You can even get by with a 20DP gear in a pinch. Our shooter/dumper is powered by a CIM with a 12-tooth 20DP, 14.5PA gear from a first generation AM Shifter. The 15mm wide, 5mm pitch belt fits into the profile perfectly and we have NEVER had any issues with that aspect of our system.
Unread 13-03-2009, 18:21
vivek16's Avatar
vivek16 vivek16 is offline
Whoa! college pilot.
AKA: vivek
FRC #2264 (trojan robotics)
Rookie Year: 2007
vivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond repute
Send a message via AIM to vivek16 Send a message via MSN to vivek16
This only works with small gears, the differences in pitch catch up with you as the gear size gets larger.
-Vivek
"we don't build robots, we build people"
Unread 13-03-2009, 22:52
-Vivek
That's sort of what I figured, but thanks for confirming it. We just picked up a gear in our shop and thought "by God! A perfect fit!"
Splice Timing Belt comphappy Technical Discussion 4 07-02-2009 09:37
timing belt ordering XXShadowXX Technical Discussion 3 26-01-2008 17:01
Timing Belt Clamp shorton Technical Discussion 10 18-07-2006 22:50
two sided timing belt archiver 2001 3 23-06-2002 22:34
Timing Belt Recommendations? Eric Reed Technical Discussion 1 10-01-2002 00:25
