| View Poll Results: What is the best strategy for scoring points? | |||
| Pinning/Blocking Robots |
47 | 38.84% |
| Scoring through robot shooter |
44 | 36.36% |
| Human Scoring |
14 | 11.57% |
| Transporting Cells (to give to other teams or human player) |
7 | 5.79% |
| Other (Specify in comment) |
9 | 7.44% |
| Voters: 121. You may not vote on this poll | |||
Re: Best Stragtey
Last year's Championship winning alliance was constructed of teams ranked 1st (1114), 12th (217), and 57th (148) out of 86. An average ranking of more than 23. In 2007 the Championship winning alliance was ranked 9th (190), 37th (987), and 50th (177), or an average rank of 32nd. Even in Lunacy this still applies. Look at the Cass Tech event, which ran 12 qualification matches. 469 started out 1-7, finished 5-7, and ranked 27th out of 40. Yet 469 was selected 2nd and reached the finals. Seeding doesn't equate directly to robot quality. While I'll agree some captains were unprepared, as they always are, most of them did a fine job in picking out who was ranked higher and lower than they should have been. |
Re: Best Stragtey
As for last year championship, An average seed of 23 out of 86 is pretty much the same average seed as 12.7 out of 52. Most games need both performance and balance. The theoretical best picks on seeding alone may not be balanced. So achieving balance often means picks that pull up the average seed. Nationals are a little bit different situation and so too are regionals with lots of teams on their second or third competition. My points were really three. 1)Teams with a chance to be ranked 12th or better should be prepared to pick their Alliance partners, 2) you don't need to worry about picking teams that are lower seeds than you - you won't ever pick them - they pick you. 3) you should have a good reason for picking higher seeds over significantly lower seeds. |
Re: Best Stragtey
our team used the strategy of having the lowest scoring bot, act as a pinner/blocker against the highest scoring bot on the other team. then our high scoring bots were free to score on the pinned bot. and the other team could not get a high score, because there best bot was pinned. this strategy can also be used to block two other bots as well.
Re: Best Stragtey
IF A ROBOT TRIES TO PIN OR BLOCK ANOTHER ROBOT THAT MEANS THAT BOTH ROBOTS ARE NOT MOVING MUCH. WHICH INTERN MEANS BOTH ROBOTS ARE PINNED. SO DRIVERS NEED NOT TO PIN BUT NEED TO JUST MOVE AS FAST AS POSSIBLE IT IS THE BEST BET TO SURVIVE
Re: Best Stragtey
Plain and simple. There are two main startegies and both work equally well.
1. Score more points than the opposing alliance. 2. Figure out how to make the opposing alliance score fewer points than you. Either one works well. |
Re: Best Stragtey
Our alliance used the same strategy throughout the elimination matches, we had 2 turret bots, and whatever you called ours(technically a shooter? maybe?). we were fast and heavy, we scored fast and scored early, kept moving and kept to our side of the field. At one point in a quarterfinal our robots pushed the other alliance into our corner from the center of the crater and held them there for maybe 30 seconds. We won our regional as the 8th seed, one of our picks was 34th, i'm not sure of the other
Re: Best Stragtey
![]() And is that you Patrick? |
Re: Best Stragtey
that's what i meant, i just flipped the numbers, and yeah
Re: Best Stragtey
We were picked by the number one seed at long beach just because of our defensive capabilities (we were 57/60). We showed teams how great we are at neutrailizing a robot.
| Best Autonomous | BornaE | Programming | 46 | 15-05-2007 17:59 |
| Best Matches (best fought not score) | ne0x0n | General Forum | 13 | 01-04-2005 12:40 |
| Best Strategy | kevin.fort | Rules/Strategy | 2 | 08-01-2005 18:06 |
| Best of... | Tom Bottiglieri | General Forum | 1 | 07-03-2004 17:49 |
| Best robot. | Gope | General Forum | 74 | 26-08-2003 16:41 |
