Problem trying to attach a file.
I can't attach a file to a post. I was able to do this last month. In addition I can not use the text tools in the message block. Is it my computer or a Chief Delphi setting?
Re: Problem trying to attach a file.
Attachments are a per-forum thing .. where are you trying to attach?
And the text tools in the message block may be a browser thing -- try clearing your cache and see if that helps. |
Good Call! I was using Firefox. When I try to attach a file using IE it works fine. Thanks
Weird -- Firefox should definitely work -- I've been using it for years on this site. Glad to see you got it worked out, though.
| How to use the data obtain in one C file to another C file? | tommy_chai | Programming | 8 | 11-01-2008 02:17 |
| SolidWorks sldprt file problem | Bosi | SolidWorks | 0 | 26-07-2006 14:59 |
| Help! making an inventor file into an autodesk file | kjhobin | Inventor | 5 | 19-03-2006 23:04 |
| IFI Loader problem - "Invalid HEX file" | wun | Programming | 9 | 22-09-2004 12:35 |
| How do we convert a modified user routines file into a valid .HEX file | HuskieRobotics | Programming | 13 | 28-02-2004 12:12 |
