Go to Post I GET that FIRST is about more than winning on the field. BUT... ...it is my experience that the great programs of the FIRST world almost always build on a foundation of competitive robots. Success on the field begets success in other realms. - Joe Johnson [more]
Unread 16-03-2009, 03:42
BurtGummer BurtGummer is offline
Electrical/Mechanical/Programming
FRC #3020
BurtGummer will become famous soon enoughBurtGummer will become famous soon enough
Modifying
What are rules on modifying the robot in the pits? Like, if I wanted to add a roller on our currently gravity powered dumper, would that be allowed? It would still pass inspection upon doing so, but I am just not sure how much we can modify our bot to perform better.
Unread 16-03-2009, 03:45
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
FRC #0254 (The Cheesy Poofs)
Re: Modifying
You can do whatever you want to your robot at the event provided you have it reinspected afterwards.
2001-2004: Team 100
2006-Present: Team 254
Unread 16-03-2009, 07:21
Billfred's Avatar
Billfred Billfred is offline
Re: Modifying
...and provided you can actually do it in the pits. Consult the At The Events section of the manual to make sure you can do what you want to do.
Unread 16-03-2009, 07:41
JAZAD1's Avatar
JAZAD1 JAZAD1 is offline
Assisant Coach
AKA: Zach
FTC #4105 (Teal Toranadoes)
Team Role: Coach
Rookie Year: 2007
JAZAD1 has a spectacular aura aboutJAZAD1 has a spectacular aura about
Re: Modifying
Make sure though that all modifications are up to date on the rules, even though the dumper sounds good double check before you do anything to it. Also make sure that all of your parts that you are using to change it are under 45lbs so that you can use them all.
2010 IRI FRC Second Place Finisher
2010 International Championship Coopertition (Galileo)
2010 International Championship #1 Seed (Galileo)
2010 NC FRC Motorola Quality Award
2010 NC FRC Regional Winner
2010 VA FRC Regional Winner
2010 VA FRC Engineering Inspiration
2009 VA (S) FTC Inspire Award
2009 VA(S) FTC Division Finalist
2009 VA FTC PTC Desgin Award
2009 International Championship Spirit Award
2009 VA FRC Regional Champion
2009 VA Regional Chairman's Award
2009 VA Website Excellence
2008 VA FTC Regional Champion
2008 VA FRC Regional Champion
2008 VA Regional Chairman's Award
2008 VA Xerox Creativity
Unread 16-03-2009, 08:00
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
Re: Modifying
Please check in with your lead inspector prior to the change. They might have some suggestions on the best way to accomplish your goals and explain how to stay within the rules prior to your commitment to change. there is nothing worse than having spent a great deal of time working on something, only to have it break one of the robot rules or extend outside of the bumper perimeter.
Al
WB9UVJ
www.wildstang.org
________________________
Unread 16-03-2009, 14:36
Chris is me's Avatar
AKA: Pinecone
Re: Modifying
I believe if the part is not fabricated when you enter the pits that you can use it regardless of weight, right? I'm not sure, thankfully we didn't need to add more than our carrying allowance to our robot this year.
Personally I would make the change if you can before being inspected so you don't have to go through the whole thing twice.
Unread 16-03-2009, 14:45
EricH's Avatar
EricH EricH is offline
New year, new team
FRC #1197 (Torbots)
Re: Modifying
Having seen the robot in question myself, I'd say that you might want to look at that bar that keeps the balls in as a starting point. I think your best bet would be to replace that bar with the roller and tweak the lengths on that linkage system.
And remember, you can make the roller during your time here, but make sure it's less than 40 lbs with any other fabricated items needed for that or for the intake system. COTS items (say, motors) don't count in the allowance.
Note: These guys only have one more event: Atlanta. Best to make the stuff at their base and ship it there/put it in luggage.
Note 2: For those that didn't understand my first paragraph, their dumper looks like a flat piece of plywood with an aluminum bar on the open side. They fire one relatively small piston, and through a linkage set, the bar pops up and the back side of the plywood does the same.
Past teams:
2003-2007: FRC0330 BeachBots
2008: FRC1135 Shmoebotics
Unread 16-03-2009, 18:28
FRC #3020
Re: Modifying
Yea Eric, I was going to remove the gate that opens which is linked to the plywood and replace it with a stationary roller powered by a CIM. The plywood base would still lift up when i want to dump, but the roller would also turn on at the same time to get the balls out much faster. It was a problem I noticed at the LA Regional.
If I could, I would rotate the entire base 90 degrees to make it a wide-bot instead of its current narrow configuration. But it's a bit late for that now. Changing to forward dumping would be nice also, but it is also a bit much.
Unread 17-03-2009, 07:31
Unsung FIRST Hero
Rookie Year: 1996
Re: Modifying
It's not over till it's over. Beatty has, on occasion, rebuilt their entire robot on Thursday if the need suited it.
Al
WB9UVJ
www.wildstang.org
[OCCRA]: Modifying Shafts tdlrali OCCRA Q&A 1 30-09-2006 14:08
modifying parts? firstborn Motors 12 20-01-2006 14:35
Modifying Motors Gun Technical Discussion 2 27-02-2003 15:11
modifying sprockets gail OCCRA 3 05-10-2002 12:13
Modifying Casters Jim Meyer OCCRA 1 05-10-2001 21:15
