Go to Post "By three ways we may learn wisdom: first is by reflection, which is noblest; second by imitation, which is easiest; and third by experience , which is the bitterest." - bEdhEd [more]
Unread 17-03-2009, 08:56
windell747 windell747 is offline
FRC #2477
windell747 will become famous soon enoughwindell747 will become famous soon enough
problems with velocity readout from encoderget vi
Hi, We are programming (still) our traction control for our bot since I'm the only programmer for our team and I'm having trouble with reading sensible values from the velocity outpu of the encoder get vi. The distance is reading fine, however, the velocity keeps resetting to zero or stays at zero.
Does anyone know what my problem might be? I tried using the example code without modification and I have the same problem.
Thanks!
Unread 17-03-2009, 09:03
PhilBot's Avatar
PhilBot PhilBot is offline
Get a life? This IS my life!
AKA: Phil Malone
FRC #1629 (GaCo: The Garrett Coalition)
PhilBot has a reputation beyond reputePhilBot has a reputation beyond reputePhilBot has a reputation beyond reputePhilBot has a reputation beyond reputePhilBot has a reputation beyond reputePhilBot has a reputation beyond reputePhilBot has a reputation beyond reputePhilBot has a reputation beyond reputePhilBot has a reputation beyond reputePhilBot has a reputation beyond reputePhilBot has a reputation beyond repute
Re: problems with velocity readout from encoderget vi
Make sure that the " minimum rate" parameter is not set too high. We scaled our output to ftc/sec, so the default min rate was too big. If your measured rate drops below the min, the output is set to zero, and the "stopped" output goes true. Watch the "stopped" output.
Phil Malone
Garrett Engineering And Robotics Society (GEARS) founder.
http://www.GEARSinc.org
FRC1629 Mentor, FTC2818 Coach, FTC4240 Mentor, FLL NeXTGEN Mentor
Unread 17-03-2009, 12:11
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
It sounds like you may have found the bug mentioned here: http://forums.usfirst.org/showpost.p...5&postcount=34
Unread 25-03-2009, 13:47
Brdn666's Avatar
Brdn666 Brdn666 is offline
AKA: Brandon
FRC #2604 (Metal & Soul)
Brdn666 is an unknown quantity at this point
Send a message via Yahoo to Brdn666
If you still can't get it, you can use the counter. The period output works for speed. One rev (Count of the counter) is one rev. of the encoder. Multiply that by the circumference of the wheel or whatever and you got the speed. You also get rev. here. You can multiply that by the circumference to get distance too.. that would save space. You must have a Digsrc if the encoder is analog!! You get some example code for it.
Problems undeploying a program from the cRIO ellisk Programming 2 29-12-2008 16:21
Gyro problems, crossposted from Electrical EFastring Programming 4 05-02-2008 10:16
Problems Using PID for Velocity Astronouth7303 Programming 6 10-02-2006 09:00
Digital Caliper as a Digital Readout on Small Mill sanddrag Technical Discussion 9 13-10-2005 22:51
Translating pressure sensor readout into actual pressure Mercutio Pneumatics 0 13-02-2004 16:29
