Go to Post Hearing about the beginnings of 842 was truly inspirational and has really stuck with me through the years. After following you guys for so long it was crazy for me to play with you. Thank you for all that you have done for FIRST in Arizona. - Saberbot [more]
Unread 17-03-2009, 09:53
cau.denny cau.denny is offline
None #1234
cau.denny is an unknown quantity at this point
encoder code for 18f8520
hi guys,
im using first 18f8520 and i need to read a encoder.
my encoder have 90 slits on it.
can eneyone help me with the code?
thanks
Unread 17-03-2009, 12:15
Mark McLeod's Avatar
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
Re: encoder code for 18f8520
Take a look at: http://kevin.org/frc/2005/frc_encoder.zip
Kevin Watson did an example of a quadrature encoder. If you have a single phase wire coming out of your Vex encoder (new ones are quad encoders, old ones are single phase) then you can still use this, but it will only count up.
Unread 17-03-2009, 12:51
None #1234
thanks
Encoder Code dboisvert C/C++ 11 20-01-2011 18:57
Encoder Code Kevin Watson Programming 47 18-02-2008 12:56
Gear encoder code Demothesis Programming 8 20-07-2007 17:15
Vex Encoder Code CircularLogic FIRST Tech Challenge 7 09-08-2006 22:12
Updated Encoder Code Available Kevin Watson Programming 2 04-01-2005 01:00
