Return DS Rev #
Is there a variable or something with the DriversStation class to return the Rev number?
I'm trying to get a custom display working just for fun, but I can't find anything in the WPI Libraries for this. |
Re: Return DS Rev #
I'm not sure how to go about doing this, but I don't think it should be necessary. The DS rev number can already be viewed in the default view and should only be needed for inspection.
Re: Return DS Rev #
Oh no, it's in no way necessary - I just felt like doing it because I'm sitting at Lansing and our bot is working fine, just wanted to have a bit of fun with the DS - but I figured I might as well make it function normally or whatever while having fun too.
There's a custom class and everything that you have to use to get it to work, I have that, I just can't figure out how to return the rev num |
Re: Return DS Rev #
Boredom is quite fun: I've been working on a pong mode for our DS using the joysticks. It's not finished yet, but I'll post code once it's done.
Re: Return DS Rev #
Bahahaha that sounds awesome, I cant wait to play it.
Re: Return DS Rev #
I was bored (that is my line that gets the other programmers knowing i wrote something interesting and complex) at the boilermaker, and so i wrote a simple pong, not very long, I have not had a chance to test it, but the other programmers thought that it works. it loops through evry .05 seconds and moves according to the joysticsk, and the ball bounces around negating the direction when it hits bounds.
Re: Return DS Rev #
Re: Return DS Rev #
(and a way to not be bored) |
| Renumbering of rules in rev F and Rev G of section 8 | Joe Ross | Rules/Strategy | 3 | 02-02-2009 21:46 |
| pic: Evolution of a gearbox rev 4 | roboticWanderor | Extra Discussion | 9 | 27-05-2008 09:19 |
| relay fwd & rev | Windward | Programming | 1 | 28-01-2006 14:03 |
| Rev. 2 Blueprint corrections | archiver | 2001 | 3 | 23-06-2002 22:36 |
