Go to Post Two students with no clue but enough dedication to work on something is always better than one expert who doesn't care enough not to leaveit until the last day. - Matt Krass [more]
Unread 03-21-2009, 11:16 AM
Shadow503's Avatar
Shadow503 Shadow503 is offline
printf("\r\n Moo!");
Team Role: Human Player
Rookie Year: 1991
Shadow503 will become famous soon enoughShadow503 will become famous soon enough
Exclamation HELP: Robot Crash in Autonomous
I wrote some code for a simple table based autonomous mode, but whenever we ran it, the robot completely crashed (random motors will thrash around a split second before the thing finally dies).
I figure there must a seg fault caused by to the way I'm using a struct pointer, but I don't know enough C++ to get this coded the right way.
Anyone got a spare moment to look over the code? Thanks for your time!
auto_commands_2009.h:
Code:
//autonomous commands
#define AUTO_STOP			0
#define AUTO_DRIVE_4WHEEL	1
#define AUTO_DRIVE_PIVOT	2
#define AUTO_DRIVE_TANK		3
#define AUTO_DRIVE_CRAB		4
struct commands
	int steer_mode;
	double time;
	double speed;
	double angle;
struct Command
	int command;	//what command to run
	double param1;	//usually time
	double param2;	//usually speed
	double param3;	//usually angle
struct Command command_list_0[] = {	//DEFAULT - STAY STOPPED
		//   Command        parm 1     	parm 2   	parm 3
		//	Steer mode		Time(Sec)	Speed		Angle
		{AUTO_STOP,       	0.0,        0.0,     	0.0}
struct Command command_list_1[] = {
{AUTO_DRIVE_4WHEEL,       	1.0,        10.0,     	0.0},
{AUTO_DRIVE_PIVOT,         	1.0,        10.0,     	10.0},
{AUTO_DRIVE_4WHEEL,         1.0,        10.0,     	10.0},
{AUTO_DRIVE_PIVOT,         1.0,        0.0,      	0.0},
{AUTO_STOP,          		1.0,       0.0,     	0.0}};
autonomous_2009.cpp:
Code:
 * Call this method to drive
 * @param speed a double describing the speed		-15fps to +15fps
void Autonomous::procTable(int AutoMode) {
	// TODO Finish autonomous code
	//		static INT32 autoSec = (INT32)GetClock() + 1;
	curTime+= TIME_PER_CYCLE;
	currentStateTime += TIME_PER_CYCLE;
	struct Command *currentCommand;
	//set the commandlist
	switch (AutoMode) {
	case AUTOMODE_0:		//Auton mode 0
		currentCommand = command_list_0;
		break;
	case AUTOMODE_1:		//Auton mode 0
		currentCommand = command_list_1;
		break;
	case AUTOMODE_2:		//Auton mode 0
		currentCommand = command_list_2;
		break;
	case AUTOMODE_3:		//Auton mode 0
		currentCommand = command_list_3;
		break;
	case AUTOMODE_4:		//Auton mode 0
		currentCommand = command_list_4;
		break;
	default:
		break;
	//behave based on the current command
	switch (currentCommand[cur_command].command) {
	case AUTO_STOP:			//robot stopped
	default:
		reqDriveSpeed = 0.0;				// Requested Drive speed
		reqAngle = 0.0;						// Requested steer angle
		reqDriveMode = STEER_MODE_4WHEEL;	// Requested Drive Mode
		if(currentCommand[cur_command].param1 != 0 && currentStateTime >= currentCommand[cur_command].param1 ) {	//time to move on to next state
			if(cur_command + 1 < sizeof(currentCommand)) {	//there is another command to run
				cur_command++;	//increment to next command
				currentStateTime = 0; //move on to next state
		break;
Unread 03-21-2009, 11:26 AM
Sentient's Avatar
Sentient Sentient is offline
FRC #0639 (Code Red)
Sentient is on a distinguished road
Re: HELP: Robot Crash in Autonomous
I'm not sure if this is the root of your problem, but I don't believe you are using structs properly, and I think it's strange the compiler didn't catch it. You only need the "struct" keyword before Command when you declare the struct. So, you don't need so say
Code:
but rather
Code:
The only place you need the struct keyword is here, when you declare the struct:
Code:
struct Command
You did this quite a bit. I hope this fixes the problem. C++ may be doing something weird and unpredictable because of all those extra struct keywords.
Unread 03-21-2009, 12:44 PM
Shadow503's Avatar
printf(&quot;\r\n Moo!&quot;);
Rookie Year: 1991
Thanks! I'll try that during the next build window!
Unread 03-22-2009, 12:43 AM
Pancake Pancake is offline
FRC #0991 (The Dukes)
Team Role: Photography
Pancake is an unknown quantity at this point
If you're looping the Autonomous::procTable(int AutoMode), make sure to delete the *currentCommand pointer.
And if you're using WPILib, I fail to see the point for using structs...
Team Webmaster
Unread 03-22-2009, 11:38 AM
heydowns's Avatar
heydowns heydowns is offline
AKA: Jeff Downs
FRC #1511 (Rolling Thunder)
heydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond repute
Originally Posted by Shadow503 View Post
Code:
This is at least part of the problem you are experiencing. "sizeof(currentCommand)" will not give the size of the commands array. sizeof evaluates at compile time to the size of a type, or, when used with a variable, the type of the variable. currentCommand's type is "struct Command *". So, the sizeof (regardless of which command table is chosen to have currentCommand point to) will always evaluate to the size of a struct Command pointer (probably 4). This could be greater than the actual size of your command table, causing your program to potentially walk off the end of an array.
The easiest way to change this would be to add another command type that signifies the end of the command table. When your autonomous code sees that command as it processes the table, it knows it has reached the last entry.
Unread 03-22-2009, 09:06 PM
byteit101's Avatar
byteit101 byteit101 is offline
WPILib maintainer (WPI)
AKA: Patrick Plenefisch
no team (The Cat Attack (Formerly))
byteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of light
also if you do this
Code:
 type *varname;
varname=value;
you assign varname's address at memory the value of value
you need to do this
Code:
type *varname;
*varname=value;
OR
type *varname;
varname=&value;
EDIT: if you do int* evilval; evilval=anynumber, especialy low ones like 0; and then later *evilval = another number; another number is going into the memory address anynumber crashing the computer, which is what i did when i was not thinking earlier in the season
Bubble Wrap: programmers rewards
Watchdog.Kill();
printf("Watchdog is Dead, Celebrate!");
How to make a self aware robot: while (∞) cout<<(sqrt(-∞)/-0);
Previously FRC 451 (The Cat Attack)
Now part of the class of 2016 at WPI & helping on WPILib
Unread 03-23-2009, 12:33 AM
heydowns's Avatar
AKA: Jeff Downs
Originally Posted by byteit101 View Post
also if you do this
Code:
 type *varname;
varname=value;
you need to do this
Code:
type *varname;
*varname=value;
OR
type *varname;
varname=&value;
Generally speaking, yes. However, OP's assignment of the only pointer he is using is correct:
Code:
currentCommand = command_list_X;
command_list_X is an array of "struct Command". Assigning to a pointer using an array (of the same base type) is perfectly legitimate and will simply result in the pointer pointing to the base of the array.
Very Strange cRIO Crash Hunter1100 C/C++ 0 01-19-2009 04:39 PM
HDD crash, need help recovering data! David Kelly IT / Communications 16 05-28-2007 11:25 PM
PlasmaCam Crash Course Andrew Blair Technical Discussion 0 12-30-2005 09:48 PM
Prom Night Crash Nate Edwards General Forum 5 05-28-2005 03:15 PM
3dsmax5 Crash? yangotang Inventor 5 03-09-2003 09:17 PM
