Go to Post It doesn't matter what goes wrong as long as you have fun. We all thought this was one of our best trips, even though we were second to last in our divison. - afowl [more]
Unread 01-10-2001, 21:41
Josh Treisner Josh Treisner is offline
#0365 (Miracle Workerz)
Josh Treisner is an unknown quantity at this point
Send a message via ICQ to Josh Treisner Send a message via AIM to Josh Treisner
Question Bosch Drill Motor Mounting
Does anyone have any ideas on how a Bosch drill motor could be mounted without keeping it in it's plastic casing? I'm preferably looking for a relativly cheap way that doesn't involve serious machining. Thanks!
Unread 01-10-2001, 22:31
Clark Gilbert's Avatar
Clark Gilbert Clark Gilbert is offline
Rookie Year: 2000
Clark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond repute
White Papers......
U could look in the White Papers section for some ideas from my team (Andy Baker)-45.......although these are not easy to make they could set off an idea that would be......
Mount Idea 1
Mount Idea 2
Purdue Alumni
Cummins, Inc.
Unread 02-10-2001, 22:15
Andrew Rudolph's Avatar
Andrew Rudolph Andrew Rudolph is offline
Git 'em!
no team (Robot in 3 Days)
Rookie Year: 2000
Andrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond repute
Send a message via AIM to Andrew Rudolph
well all you need to do is just some pieces of aluminum plate thats thick enough to put a bolt through and tap. Then u cut them into squares. Then cut out the shapes of the drill for every few inches or so, kinda like if you were to draw the motor in a 3d modeling prgram, then put some planes through it and cut the shape of the motor at that spot out of the plane. Then you cut them in half and bolt it all together and viola. Another thind is take a big block of aluminum and just mill out the shape diameter of the motor and then another for the transmission and use bolts like a set screw to hold it in.
Andrew
Unread 11-10-2001, 12:57
Jim Meyer's Avatar
Jim Meyer Jim Meyer is offline
Engineering Mentor
None #0067 (HOT)
Rookie Year: 2000
Jim Meyer has a reputation beyond reputeJim Meyer has a reputation beyond reputeJim Meyer has a reputation beyond reputeJim Meyer has a reputation beyond reputeJim Meyer has a reputation beyond reputeJim Meyer has a reputation beyond reputeJim Meyer has a reputation beyond reputeJim Meyer has a reputation beyond reputeJim Meyer has a reputation beyond reputeJim Meyer has a reputation beyond reputeJim Meyer has a reputation beyond repute
Another Method...
The students on our OCCRA (Oakland County Competitive Robotics Association) team this year are mounting the gear boxes by trapping the four tabs on the gearboxes between pieces of angle aluminum. There seems to be a lot of hand fitting (filing and such) involved but so far they have held up pretty well. This mounting requires that the output shaft be supported in two places and constrained axially.
White Paper Discuss: Locking the Bosch 3360 Drill in low gear CD47-Bot Extra Discussion 4 05-08-2003 02:10
Replacement Bosch drill motor assembly james700 Motors 3 31-01-2003 21:08
Should FIRST include Bosch Drill Motors in Next Years Kit of Parts mtaman02 Motors 9 05-07-2002 16:32
BOSCH Drill Transmission Assembly archiver 2001 2 23-06-2002 22:08
Bosch Drill Motor CAD Files Madison Inventor 10 09-12-2001 00:14
