| View Poll Results: how many usb ports do you use? | |||
| 1 |
2 | 3.92% |
| 2 |
21 | 41.18% |
| 3 |
24 | 47.06% |
| 4 |
4 | 7.84% |
| Voters: 51. You may not vote on this poll | |||
usb ports
How many usb ports do you use on the driver station?
Re: usb ports
none
everything is wired into the digital and analog input pins Last edited by NickE : 31-03-2009 at 20:17. |
Re: usb ports
We used three this year, all kit joysticks. If we wanted, we could easily dump one for a couple of switches and (if we wanted more granular control of roller speed) pots. We probably will, given that we had to borrow one joystick from 1730 at Palmetto and have since returned it.
Re: usb ports
We are using three. Two are joysticks for tank drive and one is a gamepad for control of our two conveyors, our shooter speed and turret rotation.
Re: usb ports
We have 3
1 For turning the wheelboxes, 1 is for Drive CIM power, 1 is for manipulator control |
Re: usb ports
4
2 kit sticks- Shooter roller speed control (we have 5 brushes with two motors driving them, lower 3 and upper 2) 1 Logitech 3d Pro something or another (can't remember exact name, slightly nicer twist stick, can be used for speed of motors and to turn via twisting) 1 Small racing wheel by thrustmaster as another way to steer the robot |
Re: usb ports
do you have any pics of your drivers station?
Our driver has a Logitech Wheel for steering and a Joystick for Speed and special controls. Our shooter has a joystick but we only use the buttons on it |
Re: usb ports
http://www.team254.com/gallery/2009/...01dap.jpg.html http://www.team254.com/gallery/2009/...03dap.jpg.html |
Re: usb ports
we used 3 usb ports. two joysticks were used for takns drive and the third one was used to control extra motors and pnuematics.
#10
Re: usb ports
We use two for normal robot operation (i.e. one for driving and one for the belts), and a third for debugging (which is not attached during matches).
| RE: USB ports not working | jblay | General Forum | 2 | 07-02-2009 19:12 |
| away around the USB chicklet for using USB Controllers | Stobei | Programming | 2 | 26-01-2008 14:27 |
| Gameport to Usb cable vrs. Usb Chicklet | haywirerobotics | Control System | 4 | 25-01-2007 19:03 |
| Serial ports | teh_pwnerer795 | Programming | 2 | 27-12-2006 00:47 |
| Serial ports | Cuog | Programming | 3 | 02-05-2006 12:32 |
