Go to Post Don't just build a robot; build up your community. - Pat Arnold [more]
Go Back   Chief Delphi > Technical > CAD > SolidWorks
Unread 02-04-2009, 16:59
Tri_Lam's Avatar
Tri_Lam Tri_Lam is offline
Jeff
FRC #1372 (Lambda Cubed)
Tri_Lam will become famous soon enough
Send a message via AIM to Tri_Lam
Using solid works student edition for work
The main website was kinda ambiguous here is what it said
The software is essentially functionally identical, with one major exception. Institutional licenses and commercial licenses are subscription-based. That is, they can be renewed on an annual basis, and upgraded. The SolidWorks Student Edition is a 24-month, limited-term-use license, which means the software will expire twenty four months after registration. It cannot be renewed or upgraded. The SolidWorks Student Edition has a different registration and installation procedure designed for student users, as well as a soft-lock and other features that make this product unsuitable for institutional or commercial use.
its claims it is only unsuitable. does this mean i can still use it for work?
for eligibility it also says
SolidWorks Student Edition purchase eligibility
The SolidWorks Student Edition is available to degree-seeking students or full-time faculty members using the software for personal learning or academic purposes.
A “degree-seeking student” is defined as a student who can confirm enrollment in a degree-granting program, or who can confirm full-time enrollment in a certificate-granting program. Do not purchase this software if you're not a degree-seeking student or a full-time faculty member. Commercial and institutional use is prohibited.
i am currently a college student and i see using this software at work will let me to see how this really works. (and educational experience)
please respond
Mira Mesa High - Lambda Cubed
2004 - ???
2005 - LA Regional
2006 - Las Vegas Regional - 7th place
2007 - SAN DIEGO regional
2008 - MMHS's Advisor is too cheap -_- 1372 may be no more.....
Solid Works For Mac (Petition) Madwolvez SolidWorks 7 14-12-2008 20:41
Solid Works, Student Edition merybar General Forum 2 03-05-2008 07:38
Solid Works instead of Inventor for AIA? Pneumaticsman CAD 9 24-03-2008 20:34
Class for Solid work mihiraum SolidWorks 0 10-12-2007 23:46
solid edge solid works ceileachair Inventor 1 21-01-2003 22:03
