Go to Post "GP" isn't a gauge, it's a target. - Rich Kressly [more]
Unread 03-04-2009, 13:32
kapolavery's Avatar
kapolavery kapolavery is offline
All Your Base Are Belong to FIRST
AKA: Avery-John Domingo
FRC #2445 (RoboKAP)
kapolavery is a splendid one to beholdkapolavery is a splendid one to beholdkapolavery is a splendid one to beholdkapolavery is a splendid one to beholdkapolavery is a splendid one to beholdkapolavery is a splendid one to beholdkapolavery is a splendid one to beholdkapolavery is a splendid one to behold
Victor Vs Jaguar
in what scenario would you use the victor speed control and in what scenario would you use the Jaguar
this year our team used all the kit jaguars for our turret, shooter, and drive
and another question i had was what is the max you could push the speed control (either one) without burning out..
our programmer didnt want to push it pass one.. but were there anyteams that did that?
is it also possible to hook up speed controllers in series so that you can max out the speeds?
"There's always next year..."
Unread 03-04-2009, 13:55
Phil Ross's Avatar
Phil Ross Phil Ross is offline
Constantly Inspired
FRC #1712 (Dawgma)
Phil Ross is a splendid one to beholdPhil Ross is a splendid one to beholdPhil Ross is a splendid one to beholdPhil Ross is a splendid one to beholdPhil Ross is a splendid one to beholdPhil Ross is a splendid one to beholdPhil Ross is a splendid one to behold
Send a message via AIM to Phil Ross
Re: Victor Vs Jaguar
I don't know the specifics of how far you can push them but I heard stories about teams who had their jaguars at 1+ and they blew up and melted. At some point there were pictures of the aftermath. I think by build season next year we will know a lot more about the control system and be able to know just how far we can push this new technology.
Are team decided to stick with what we knew for this year and used only victors on our robot, next year we may switch or do a mix or not. We shall see next year.
FIRST Americorps VISTA, Philadelphia
DAWGMA TEAM 1712: Alumni (2006-2009)
Unread 03-04-2009, 14:30
EricVanWyk EricVanWyk is offline
Rookie Year: 2000
EricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond repute
Send a message via AIM to EricVanWyk
The "behind the scenes" software clamps the values at +1 or -1. Attempting to go 2 is equivalent to a 1.
In series? You would actually reduce your available power, and it is illegal.
In parallel? You would theoretically increase your available current, but it is illegal and dangerous.
Unread 03-04-2009, 14:56
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
Avery,
The internal circuitry of the either the Victor or the Jaguar switches between the positive and negative leads of the battery. The switching is not synchronous (meaning all devices will not go high at the same time, etc.) so it is possible and likely that two controllers in series would allow the series connection to have one wire at +12 volts while the other is at zero. The result would be catastrophic with max battery current (600+ amps) flowing through both controllers and the wiring in between. The same holds true for controllers in parallel. That is why the rules allow one and only one controller per motor. At full throttle on either controller, the output goes to DC (no PWM output except for a short pulse on the Jaguar) and so there should be little difference between the two types of controllers. The Jaguar uses a 0.0005 ohm resistor for current sense but the FETs have a lower "on" resistance than the Victors so it's pretty much a wash.
Al
WB9UVJ
www.wildstang.org
________________________
Unread 03-04-2009, 18:41
kapolavery's Avatar
FRC #2445 (RoboKAP)
ok i see..
just wanted to know that
thanks!
Unread 03-04-2009, 20:26
kapolavery's Avatar
FRC #2445 (RoboKAP)
ok and this leads me to my next question
how are you able to bypass the limit it can handle so that you can get the max value
or is it all dependent on the how you make the drive train, the gear ratios, etc..
Unread 03-04-2009, 20:31
EricH's Avatar
EricH EricH is offline
New year, new team
FRC #1197 (Torbots)
You'd have to tamper with the "behind the scenes" software, which is a bad idea.
Changing your drivetrain gearing is a much better idea.
Past teams:
2003-2007: FRC0330 BeachBots
2008: FRC1135 Shmoebotics
Unread 03-04-2009, 20:36
kapolavery's Avatar
FRC #2445 (RoboKAP)
ok that answers my main question
ill have to go research a new drive train for next year
Unread 03-04-2009, 23:46
Rookie Year: 2000
1 and -1 mean "every bit of power possible". Software can not be written to get around this. Please see "This is Spinal Tap" for reference, specifically "ours go to eleven - it is one higher than ten"
Unread 04-04-2009, 00:11
kapolavery's Avatar
FRC #2445 (RoboKAP)
is that supposed to be humourous??
haha
i get it tho..
if its not made to go past the limit, it wont go past the limit..
its like
trying to breathe with no air.. sorta thing.. right?
Unread 04-04-2009, 00:19
Qbranch Qbranch is offline
wow college goes fast.
AKA: Alex
FRC #1024 (Kil-A-Bytes)
Qbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond repute
its like
It's like, the FETs inside the drive are at 100% duty cycle and are for all intents and purposes very low resistance wires connecting the motor to the battery, sorta thing.
Going past the limit would mean a >100% duty cycle, which is impossible. A direct analogy would be working 25 hours a day.
If you do manage to figure this out though, please let me know. You'll have singlehandedly solved the world's energy crisis.
-q
Electrical Engineer Illini
1024 | Programmer '06, '07, '08 | Driver '08
Unread 04-04-2009, 10:41
Rookie Year: 2000
haha
i get it tho..
its like
Yes, it was a lame attempt at humor.
Q hit it on the head though. It is not physically possible to go past those limits.
I wouldn't describe it as breathing without air, more of a "Giving 110% effort isn't possible". If you could give 110%, then what you used to call 100% was actually only 91%.
"This Is Spinal Tap" is a mockumentary about a rock band. During an interview, they said that they were the loudest band in the business, and asked them their secret. Their response was that their amplifiers went up to 11 - it is one higher. The interviewer responded "Why don't you just make 10 louder?". "But it is eleven, it is one higher than ten!"
The [1,-1] scale was arbitrarily chosen to make math easier. We could have easily chosen [2,-2] or [255,0], but all the values would have simply scaled in response.
Changing the "behind the scenes software" would allow you to send signals that are higher or lower than the current bounds, but they wouldn't mean anything.
Unread 04-04-2009, 11:23
billbo911's Avatar
billbo911 billbo911 is offline
I prefer you give a perfect effort.
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
billbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond repute
One comment, one question.
Kapolavery,
I've noticed you around CD a lot lately. You ask a lot of really good questions. Although some of these could actually be answered by doing a search, the honesty in which you ask and the detail you give in what you are looking for is quite refreshing. KEEP IT UP!!! (Aloha, and welcome to CD).
Eric,
Now that the math has been simplified by making the input control range -1 to 1; how many places of resolution after the decimal point does the Jaguar have? In other words, will sending .2508 be any different than sending .25? I realize this is only a .32% difference, but I am really looking for the limitations that the input has on it, not the actual output. Would anything over 2 places even be read by the Jag?
CalGames 2009 Autonomous Champion Award winner
Sacramento 2010 Creativity in Design winner, Sacramento 2010 Quarter finalist
2011 Sacramento Finalist, 2011 Madtown Engineering Inspiration Award.
2012 Sacramento Semi-Finals, 2012 Sacramento Innovation in Control Award, 2012 SVR Judges Award.
2012 CalGames Autonomous Challenge Award winner ($$$).
2014 2X Rockwell Automation: Innovation in Control Award (CVR and SAC). Curie Division Gracious Professionalism Award.
2014 Capital City Classic Winner AND Runner Up. Madtown Throwdown: Runner up.
2015 Innovation in Control Award, Sacramento.
2016 Chezy Champs Finalist, 2016 MTTD Finalist
Unread 04-04-2009, 12:00
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Originally Posted by billbo911 View Post
...how many places of resolution after the decimal point does the Jaguar have?
The resolution is limited by the cRIO Digital outputs before the Jaguar sees the signal in the first place. The outputs have a 6.625 microsecond update rate, so there are only about 150 different pulse widths possible between the 1ms and 2ms limits of a standard servo-type signal.
  #15   Spotlight this post!
Unread 04-04-2009, 12:23
Rookie Year: 2000
Eric,
Bill -
Alan's post is only half correct. It is true that the outputs have a 6.625uS update rate, which does equate to 150 signals over the standard window.
However, this is slightly higher resolution than the Victors can respond to. Additionally, the Jaguar does not use the standard 1ms - 2ms window by default (it can be set to do so). It uses a wider window in order to get more resolution. This is why you must use the Jaguar or Victor specific API calls - they will scale the pulse width accordingly.
I don't have access to the exact numbers right now - I've managed to get out of the office this weekend. Hopefully someone with better knowledge of the specifics will jump in.
I'm 30% confident that internally, the Jaguars represent the Duty cycle with a 16 bit number (even though they are using a 32 bit processor). I'd be surprised if we are getting more than 8bits over the PWM channel, so this extra resolution isn't used (this year).
Yellow Flashing Jaguar/Victor Lights AlbertW90 Electrical 10 16-02-2009 11:06
Increase Victor and Jaguar pulse resolution Bryscus FRC Control System 8 26-01-2009 20:20
Can I control a victor/jaguar with an RC receiver Bruceb Electrical 3 30-12-2008 10:50
Jaguar and Victor Flashing lights? programmr FRC Control System 24 17-12-2008 15:44
pic: Jaguar next to Victor ajlapp Extra Discussion 26 10-08-2008 17:56
